Ye but it only ran 135mph - SIF 900rwkw
yep, absolutely no way. Even if it had a lazy take off (which it did) and has low 'average' power, it should still have pulled off 145
I found that comical considering my ET was 129.75mph with only 320awkw
My mates xr6 ran a 10.9 with 400rwkw
130mph just tells me the dyno figure you are quoting is low. At 130mph you should have 500-520rwhp (370-390rwkw)
That was in my r32gtr with street radials, 320awkw was on a dyno dynamics dyno as well (crd tune).
I think I'm a good driver :) 60 foot was 1.5s from memory...
It doesn't matter if you take 20 seconds to get off the line, your top end speed will be similar
they dont do mph tho like gtr's. have a look at any ford v8 with a s/c, even with huge power they just dont run the mph for some reason. the turb is always faster with the same power.
that doesn't make any sense.
Edited by Rolls
so does that mean the dyno is out by like 700hp ?
60 foot generally has no effect on trap speed.
I ran the same mph on street tyres as i did on slicks.
I found that it did, minor - but it was consistent as i raced every 2nd week for 6 months :D
This is what i was doing when on the same tyres with varying 60fts.
1.9 60ft - 109mph (12.9 ET)
2.1 60ft - 110-111mph (13.2 ET)
But yes, marko - you didnt have 320rwkw with a 11.1 @ 130mph, over 350.
That is interesting ash as crd's dyno isn't optimistic so u might be right...I know that my tuner did tell me to convert from awkw to rwkw I'd need to add close to 10%, therefore 320awkw might equate to 350rwkw
i know but that is how it happens. do some reasearch and u will see what i mean.
It has nothing to do with the fact it is turbo or v8, the reason they have different speeds is turbo cars (skylines etc) have much better drag coefficients than V8s from the 70s, they are also usually quite a bit lighter. It has absolutely nothing to do with the engine, power is power, it won't go faster just because it is a turbo :P
lol, I can get a camry to read 1200hp. Not saying it doesn't make a lot of power, just saying it doesn't make as much as they claim...unless ofcourse, he backed off at the end like someone said.
I don't think I'd post a 11sec run on youtube if I did one with that much hp
Also rolls there power curves are usually pretty different, Im not sure about the supercharged v8s, but when i was comparing the NA V8 torque/power curves to my rb30, i noticed that the v8s power curves usually have pretty flat torque curves that result in the peak power being made almost at their peak RPM, while my car had a lot less torque off boost, but once on boost picked up a lot of torque through the mid-range and started dropping off a fair way before redline, so although they made the same peak power, my car had more torque in the top end, as its power curve had a rounded top earlier in the rev range while the NA v8 had a straight line power curve. If the supercharged dyno curves are similar could explain it.. tho im stikking a v8 in a r32, so i suppose we'll see what sort of top end speed it will get with a car thats light and has a descent drag coefficient.
Anyone got a gt3788r dyno curve yet?? I've been following this thread waiting for someone to post one, so i can compare the response to my gt35r
Jarrod
Yes, you are correct... People don't often understand the concept of why when your 60ft is lower the mph is lower. When you do a quicker 60ft you do a quicker ET, a quicker ET allows your car less time to accelerate and thus is going slower at the finish line.
Got a tip for you guys, an R32 skyline has a f**king atrocious drag coefficient like almost 0.4 or something.
I've heard that they've got a good one, and i've heard that they've got a horrible one. Hard facts please people, sick of the hearsay.
.40 it is, seems i was getting it confused with something else (and not the new gtr either)
Edited by sneakey pete
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
