i can't see my setup being anywhere close to a RB30 with -5's, (i'd choose that combo as well if going down that road, but with a neo head as well :D)
9 sec ramp i believe,
the interesting thing i found is how this setup compared to a 26 with vcam, very similar results, see..
as for mods, head has had some porting done i believe, baby cams though. Tomei expreme manifolds - midori dumps i think, middori s/s front pipes, midori titanium catback, not 100% sure of diametre - sard cat
meh, the 30 is always going to make more power sub 5,000 rpm but 5,000-8,000 I reckon the 26 will make at least as much. when you're up it there's not much time spent sub 4,500 or even sub 5,000 in a GTR. if it's a track car and you take the 26 to 9,000 (which is easily done with just some valve springs really) then see how the 2 compare.
don't get me wrong. I like the 30s and they have their place. for certain applications they are better than a 26. but not in ALL applications. both engines have their ups and downs.
don't forget as well daniels engine is a fairly basic 26 build. pretty much blueprinted, N1 type engine with mild cams. I'm sure with headwork etc it could probably make even more. but shit who really needs more than 400kw atw????? it's a road car after all and a fking nice one at that. it's not just the 400kw, it's the fact it's a 1 owner since new Nur, low kms, immaculate body and interior, and all the nice bits like big Alcons front and rear, hand made midori titanium exhaust and on and on the list goes. *sigh. such a nice GTR.
VCT for RB26 is not expensive
Are you referring to HKS Vcam or running a setup like a Neo head/modified Nissan VCT on a 26 head?
Just to clarify, I meant for the difference in those results if the vcam cost for example $4000 from hks plus fitting and tuning, to me at least it doesn't seem worth it :)
Vcam is around the $5k mark when i was looking, and then quoted about $1000 for install - then you'd need tuning time
but for those getting a workshop to do it it gets $$ because of all the labour involved, even if the parts aren't the expensive. it's the expensive RB26 labour that hurts - cheap as if you can DIY
RB26 head. We only use the R33 VCT inlet gear and the rest we make ourselves. So far, costs have been minimal but we had the cylinder head off already. That would add substantial cost to the conversion but good for anyone in the build. We are working out all our cam specs next week as we don't want pistons saying hello to valves when everything is advanced.
The difference is amazing in both boost response and power. You guys are talking about possibly going the 30 instead of a VCT setup.....what about 30 AND VCT together? I just barred up a little
I love where you're heads at (the one on your neck, not the pants)
Earlier last year I started to play with ideas using 33 vct on a 26 head but got distracted and cbf'd.
I'm already rb30, and the head has to come off...
What sort of cam specs are you aiming for? 260 with 10.25mm lift or thereabouts?
made it in by .5 of a rwkw :D
400.5rwkw
2530's
smallish cams, 256
Powerplus E85
mid to high 21psi
Racepace adj cam gears, all for response (let the E85 take care of the top end)
built 26, not 100% on pistons hence no 24psi runs etc.
what intercooler, are you running??
No I mean 26/30's with VCT
How much of a gain would you say there would be between a 26 head with VCT vs 25 neo head with VCT ?
I hope that guy leaning over the bonnet isn't listening for knock? LOL if he is
Pete from nistune told me that if you have nothing else sticking your head in the engine bay with a pair of ear muffs works quite well, up there with the garden hose over an intake bolt! lol.
Edited by Rolls
Can't tell you the cam specs sorry. That has been the most important part so far. We have spent a lot of time working out what will work and what will not including head off 2 times in a GTR in one week. I hate doing them
Our stuff is different to HKS's.
None, all the technology in the RB26 head is present in the Neo head. Valve/port angle etc. The only benefit the 26 head has is more readily available parts
Well it depends on what setup you have. If you have an ecu capable of switching a solenoid at a certain rpm, then we would be able to sort out something within a couple of weeks. We are still working on the standard ECU guys options.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
