lol, you mean lucky me? surely PI isnt that hard to get a car into??
yea i like that... but that goes on glass, is the one for behind the driver, mounted on the cross bar of a cage?
lol sorry what I meant is that any magazine article done on your car is a good thing, not everyone can say their car has been in a magazine :)
That mount can go on panels outside also but i know what you mean, you need one with a ring grip on it yeah? like these - http://www.camzilla.com.au/products/clamp-mounts
  • 1 month later...
Bumping this thread; a current 400kw club member got off the rollers last night with a slightly higher reading than before. The car is an animal now!
Anyone else breaking into the 400's lately?
I'll only list a few of the major mods
R33 GTR motor
Cp pistons
Eagle Rods
Tomei oil pump
Trust 264/272 cams
Tidy'd up head ports
Arp studs through out the motor
Precision 6765 still with T3 rear housing .82
Haltec ecu
1600cc Indy whites
442kw at the wheels on 26psi.
I've now ordered at T4 divided rear 1.00 so should make some better numbers..
Edited by 26_S13
Holy wheelspin batman!!!
With normal street tyres yeah, just cruising along in 4th and put ya foot down it would start baking as soon as it come onto boost.. But with 275 Micky t ET streets it hooks up and goes, cars not manual anymore though, just bought a 2 speed for it.
Our race car cracked 441rwkws/592rwhp the other week.
RB30DET
6boost mani w/ gt35r 1.06 rear 45mm progate.
STD gtr plenum & throttles adapted to 25 head
Domed CP Pistons
Custom ring set
Spool I beam rods
Kelford 264in/272ex 10.2mm
Light Port work
1mm oversize inlet valves, 2mm oversize ex
bosch 2000cc squirters
Running off gate pressure cracks 23psi by 4000rpm from memory and then bleeds off down to 19psi by redline @ 7500. Peak power is around 6500rpm at about 20psi. Need to hook up and setup a boost controller to hold 23psi to redline.
Not a bad effort for a 35r. I will try and find the printout, though I think my old man has it somewhere.
Sorry that was using straight methanol.
Yeh it did it quite easily too. If we can get it hold the 23psi to redline, I would reckon it would easily crack over 600rwhp. First run it was at 17psi which for some reason it could hold to redline, Im guessing back pressure was at an equal level to intake pressure so the wastegate could manage it at which it made about 510rwhp. Then I changed the spring setup to a 24 psi combo and it only went to 23psi and bled back as I was saying in the other post. But at only a few psi more then the previous run it oozed out another 80 odd hp which was unexpected.
The great bit about the alcohol is the car stays nice and cool, water temps stay in check, oil doesnt get warm enough which is actually abit worrisome and the inlet manifold is cool constantly with the fuel rail chilly. It is amazing stuff.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
