People on this thread do not even knowin what gear Ben's run was done.To me it seems 5th with a 4.1:1 diff. Only way to get 230 kph at 8000rpm.
He does use 4th sometimes,and 5th soetimes.
In the R34 GTR with a six speed 5th is 1:1 with a 3.545:1 final, that is assuming the R34 the motor is in is a GTR
True if it had an r34 box in the car, but he mentions a 4.1 ratio which says r32/33 box .
R34 box in R33?
I didnt know whether or not he was running a getrag box for strength or an aftermarket gearset in a r33 box ??
Which is why i questioned what got stated before with the 5th gear 1:1 comment .
Edited by ezy_09s
Doesn't matter anyway - he hasn't looked at SAU since 2010, and hasn't owned Racepace for around that amount of time either :)
I do know where the car ended up, and given recent goings on... Recent posts have been somewhat interesting.
But anyway - back to talking about 400rwkw.
Hell perhaps we even need a 500rwkw thread given Gav's results!
Yep agree...now more info on this 500kw monster
I have no deers eyes on the cars setup, I saw R34 GTR and a question about 1:1 in 5th and thought I'd offer a answer.
4.11s can be put in with the standard R34 getrag box in place which would give it awsome acceleration, but mean it would rev off its head at 110kmph of the freeway, and still have a 1:1 ratio in the box in 5th :thumbsup:
I have run 411rwkw on a stock R32 box. However, the triple plate HKS GD Pro isn't very stock box friendly. It isn't even dog box friendly.
I recently asked what the quickest 1/4 mile time anyone knew of with the stock R32/33 box:
http://www.skylinesaustralia.com/forums/topic/395117-quickest-14-mile-et-r3233-gtr-using-stock-box/
i also ran the 1/4 mile with a stock box in my previous gtr which made 320awkw & managed a 11.1 sec with 129.75mph.
that was my last run, however, i crossed the line in 3rd gear & was bouncing on the limiter & my 60 footer wasn't that good (1.6sec?)
considering the relatively low power level i had at the time (hks gtss @ 23psi) that car was capable of a 10sec pass, but unfortunately i fudged it over the line :(
breaking boxes i think comes down to the driver & treating the box with respect, i.e. no flat changing
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
