Anyone with -5's on a 2.6 want to take me for a qick spin in sydney? Beers or petrol your way for the effort, Cheers
Been for a spin, is don is good.
No where near the lag anyone whines about at all.
Start a thread in the NSW area - you will have a better chance :)
Not a lot of -5 GTR's in here because most on an unbuilt 2.6 end up around 360/380kw
The more I see these e85 results the more I need to get my ass into gear.
Are u using pump e85?
Pump e85, just as good as any v8 super brew... been there tested all that jazz.
To put an end to all the hub dyno bullshit we run our dyno on the latest SAE correction some other operators run the older US spec din figures which inflates power.
On two occasions within 3rwkw of the mainline @ drdrifts (same day) and on average a little less than the racepace dyno (not done back to back but car was suplied with current sheets to compare too)... close to chasers as well.
Do you have a graph by any chance for that?
+1 for proof.
My 26 with -5s had full boost between 3500-4000rpm and it was very nice. Did not feel laggy at all.
Unless by "full boost" you mean 5psi... There is no way, with a 2.6ltr that you'll make 20psi at 3500rpm on PULP. There is not one car in the 2.6ltr dyno thread that comes within 500rpm of that.
Even 4000rpm you are going to struggle on a lot of setups.
My PB 60 footer was 1.5sec and I remember when it hooked up that I actually lost grip of the steering wheel. It really got me by surprise as I didn't expect those G's.
I always had a higher respect for bikes as you get into 1:1 power to weight ratio hence this was a friendly wake up call for me at the time.
I had the same power level as you and this is capable of a 10.8 pass, proof is in the pudding :)
The hi octane r32gtr ran a 9.7 on circuit slicks i think haha and that had 440kw from what I remember? It isn't even a purpose built drag race, pure circuit car :)
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
