Thermodynamics. Higher boost pressure = more heat.
For the same turbo yes. But when people are running different turbos etc then the thermodynamics of each compressor vary greatly and I think its an assumption to thing that say a GT35R running 20psi will heat the inlet air more then -5s at 17psi
.....I think what he is trying to say is that a 4L motor on an XR6 requires less boost (since its a bigger container) to get same airflow and HP as a 2.6 Litre motor does all things being equal - and therefore is concluding there is less heat to take out (due to less boost required) and hence a smaller intercooler for same or similar effective output....
...I did read that the Hybrid coolers flow real well with very little pressure drop even at some big numbers. But when you look at the inlet temp at the manifold its higher then you would like to see. Whats the general rule of thumb on inlet temps again? Its something like 10deg C is 1% of hp ?!?!?!?
What is peoples experience of intercoolers and inlet temps? I have alway observed an inlet temp within 20deg of what my AC says is ambient temp. No idea if thats good or not...i know I have a HKS air filter and no cold air shroud around it
How good are ARC coolers? Got one on my gtr, looks to be 70ish mm thick, delta fin style I think, definetly not bar and plate or tube and fin...
Would they support mid to high 300kw at 20 plus psi? It isnt that thick, could this be a problem?
It Came with the car otherwise I would of still be running the stock one lol
It's fine. Steve has a 70 mm ARC well past 400.
Daniel with the Midori 34 has a 70 mm ARC and has cracked 400 with 2530's.
Interestingly they mention the magic 400kw on their front page and offer a 'big' intercooler for it...
Doesn't say how big - just in the 'intake size'.
And read the rest of the sentence :)
If chasing numbers in the 400 rwkW plus range you can order what is known in-house as the BIG BIG cooler. Still using the same intercooler core this until has a larger alloy cast end tank that takes a 63mm inside diameter hot side intercooler pipe
Anyway I'm going on holidays for a fortnight. Keep discussing, i'll return and call you all wrong in 2 weeks :P
3500 RPM = 150 RWKW 400 nm
4000 RPM = 210 RWKW 500 nm
4500 RPM = 300 RWKW 610 nm
5000 RPM = 355 RWKW 660 nm
5500 RPM = 395 RWKW 655 nm
6000 RPM = 412 RWKW 645 nm
6500 RPM = 412 RWKW 590 nm
7200 RPM = 412 RWKW 545 nm
Limited to 7500 RPM, and running out of injectors
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
