  • 3 weeks later...
Comparison with mine shows it's very good, mind you cost vs performance I would be ahead :)
Yours does very good for the price, but given that it has more power absolutely everywhere and your turbo is nearer its limit than the GT35R is - your statement is very very subjective.
Yep meant exhaust.. Twin scroll?
Nah single
It's the internet I didn't know I had to be objective haha :)
It was more a warning to others that if you slap a GT3582R onto a standard RB25 and/or a RB25 neo (even with poncams) you are not going to get within coooeee of RRob's result for response or power.
Not as much response /power definitely, definitely. I don't agree with though power, especially assuming thats on E85.... 440+kw @ hubs on a stock RB25 with cams with a GT3582R on E85 isn't a huge shock.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
