Stao do they remain the nvcs the same as poncams? Why not just use drop in poncams? I'm fairly sure they have been proven to make 500atw's kw. Where are you getting the camshafts from? Should sound fairly angry. :)
Josh
Engines got tomei cams 260 9.5 already with about 10000kms on them,doing a 500kw build and hoping to get there with them.Tuner said its possible so spose will try.Was just wondering on all your opinions.Will be running 30psi boost with a 2.8 stroker
On Tomei's website RB25det Pon cams is only available in 256 / 8.5mm, The 264 / 8.5mm is apparently an custom item that needs to be ordered. I've been told they are the largest drop in Pon cams, CJmotors stock them. Part no.: 143021
For those with more dedicated track cars, what's the most boost you're running through your -5's?
I'm running 23psi (moves around a little upto 24). Was thinking of upping it to 25 or 26psi. Thoughts?
Will I see much of a gain or have they already run out of puff by then?
Thats with a big $$$ head and rb2.8 stroker also. Piggaz has absolutley pushed those -5's to the moon and back. It's a awesome effort.
Josh
Josh
From memory, if we pulled it back to 25 ish psi it made something like 455. Not a hell of alot to be had top end, the gains were through the midrange. It's quite noticeable too.
  • 4 weeks later...
I ran a washable originally but now run twin ryco filters as they are super fine and my fuel system originally was dirty so the rycos collect everything.
Ps- I am not worthy of posting in your thread as my HTA hasn't got what it takes, but fark it I was passing by :P
I use a washable mesh Aeroflow one seems to do the job well..
So iam in the market for a new exhaust looking at 4" and titanium if i can find it. What options are out there? I have emailed bread at Pro Fab about a custom made one any other options? Will be on HKS 2530's with a Racepace twin 3" into 4" front pipe.
Thanks
Matt
I'll ask brad if he can do a better price for two...I'm keen for something lighter and better flowing.
Car gets tuned at unigroup on Monday. Finges crossed all goes well, Hopefully i can stay in the club....it was tuned elsewhere before and was never convinced of the power figure.
How big is your exhaust now? I spose at the most it would only be a touch up tune with the bigger exhaust.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
