We ended up staying with the stock bovs, no issues whatso ever, thanks guys
Went on to make 447kw at 24.5psi
Forged 2.6
Precision 6266 t4
264 cams
BC springs
Cam gears
Plazmaman intercooler
2000cc injectors
Walbro e85 pump
Adaptronic
Caltex e70
Rb30 /26 2000 ids maxed heads titanium ferera everything 262 cams fully built bottom end cp flat pistons 10/8 comp 6 boost manifold gt2860 - 10 garrets standard plenum 456 kw atw on 17 psi run in and wind it to 30 in two weeks . On e85 . On boost by 3600 rpm hard
Forged 2.6
Precision 6266 t4
264 cams
BC springs
Cam gears
2000cc injectors
Walbro e85 pump
Adaptronic
Caltex e70
hey mate im going to be running aorund the same setup as you . except -5 turbos . what specs are you running on your head . and the walbro is it the only intank pump you have thats it ?
are you running different fuel rail and pressure reg ?
i dont know whether the -5 with upgraded actuators will see that kinda power on that setup anyone ????
  • Like 1
Mine is a standard fuel rail with a Nismo regulator. Also running standard actuators on my -5s and its happy :)
really so just one inline walbro 450 intank how much boost are u running
and what power does yours put down at treads
im trying to get a build combination together that is tested and proven something that will deff work atover 400kw without any issues
I'm running the stock intank pump with external 044 and surge tank but I can't go higher than e60 as my fuel flow is just about maxxed out (I need to add a second 044), however, SIR_RB as above is running the walbro independent. I'm thinking of running my walbro as well on its own as it's now tried and proven for 450kw!
I'm making 430kw @ 25psi.
  • Like 1
Standard fuel lines (only got e85 safe fuel hose to replace the factory stuff)
Standard fuel rail and fuel reg
Walbro 460lph pump running direct 14v with relay
No signs of it running out at my power level, running e72 (caltex eflex) has enough flow for 450kw at 25psi depending on AFR's, mines tuned at 11.8:1
My head has been decked, metal gasket with arp studs, greddy 264 cams and cam gears and brian Crower single valve springs, simple stuff realy
  • Like 1
when u say direct running voltage with relay . are you using the standard wiring with ecu triggering the relay and just adding another heavy power feed from battery to 30 on relay and 4mm twin from 87 to pump
or are you running separate relay and triggering relay straight off igntion to have pump running all the time when ignition is on
cheers
no surge tank needed then ?? everything standard fuel lines etc except fuel reg upgraded and 1 in tank walbro 450 l p/h rewired correctly to supply 13.5 v at a constant without voltage drop when car is running .
Excellent. I was wondering how much my 400l/ph Walbro E85 pump could support power wise. I run mine ECU triggered through a relay and it runs at 14v. Running it as a single intake pump just like the factory setup it seems that it should easily support my 350kw aim on E85.
  • Like 1
What size intercooler are most of you guys running for over 400rwkw?
We're currently trying to get more power out of my car but it's stuck at 360rwkw. It's a built 26 with all supporting mods, running -5's and e85. Something is restricting it and everything's been checked and it's all good which leaves us with the intercooler. Currently it's a trust 70mm tube and fin. I'd love 400rwkw or close to it if that's realistic.
Iv looked into plazmaman 76mm and apparently it's good for 800hp with new technology cores they use but not much info on them. Or am I better off with a Jap 100mm intercooler?? Perhaps even cams if that's what may be holding it back? What experiences do you guys have.
Any help is greatly appreciated.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
