Ha! Send it to wherever via my joint....it might have some intimate time with a baseball bat!
Watch this. It's a clip from office space.
The guy at 47 seconds pretty much sums up my feelings right now
http://www.youtube.com/watch?v=aWj6Hy5eMuo...be_gdata_player
PFC for the WIN :D
or if you really wanna get a high tech ecu get a microtech :( lol jokes.
deano we could run the 285s but just have to raise our cars just a tad..... like 70 mm atleast.
im soooo keen for e85, come on gossy caltex hurry up and finish the tank works :D
lol 70mm :D
haha i was just talking to a mate today about this clip, farken gold!
yeah mate, pfc is a dinosaur BUT it works
sorry about the silly question, but to the guys running over 400rwkw, if you have a twin setup do most keep it internal or external gated turbos ? any issues with boost creeping ?
internal, there are no boost control issues with decent turbos :D
lol at microlebs, seriously them and V400 wolf 3ds are a downgrade from the stock ecu, less injector drivers and less features
My ECU is able to drive two sets of injectors via primary and secondary banks, two fuel pumps + lifter - it is set up to run primary bank+one pump on cruise and light throttle/loads, with the second bank and pump trigged when boost/load increases; can idle fine despite using MASSIVE cams, and gives me great fuel economy and drivability to boot (as long as I'm not WOT'ing it everywhere :D).
Data logging, switchable maps, shift light, two-step, warning lights, boost cut, soft and harsh rev cuts, etc etc.
I'd take it any day over a PFC or stock ecu...
Yeah, 4 injector drivers lol, means all 3 injectors are firing at once, lacks sequential injection like the stock ecu and any other decent ecu, no matter what you do, all things being equal you won't get as good fuel economy nor will it be as easy to tune.
for the price and trouble of going to an aftermarket ecu, there are plenty of better ones.
Edited by Rolls
This just made me think of the VIPEC v44...it has 4 ign outputs and from what I can gather off their website, 4 injector drivers...
Four low current injector outputs. Optional Peak and Hold drivers available.
Spare injector and ignition outputs can be used for output control.
Though the line in bold confuses me...who the hell runs less than 4 cylinders?
Does this mean that the v44 is wasting fuel too?
I thought it was only the older models (of wolf and vipec) that only had 4 injector drivers, all new models run 6 or 8 injector and ignition drivers.
The fuel wastage isn't that bad, but it all adds up, it also makes it harder to tune the car to idle smoothly. Lack of ignition drivers isn't really an issue, injector ones can be though.
With 4 injector drivers you can run it in batch mode using only 2 of them, 2 driving 3 cylinders each, or 3 driving 2 cylinders each and set it up semi sequential.
Edited by Rolls
the plugin skyline version has 4 ignition drivers and 8 injector drivers.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
