Done all the pricing with the exception of the bellhousing for a R32/33 GTR gearbox(second hand box).....$2,689 but I would add another $500 for misc.
The only problem is sourcing someone to do a bellhousing.
Anyone???
Hey Craig,
was going to call today, i spoke with my friend, and he palmed me off to another friend of his, rd&g engineering whom he used to work for
he has mills and the like said either an adaptor plate or cut and weld a bell housing, said no price. as it would be a time consuming thing..
best bet would be to find a bell housing that would fit to the engine, and the 32 box.. said it could be possible.
not sure yet. might be good to think about another box that will take the transfer in the rear?
i will have a chat to him again. and see what he says.. its a tricky one for sure.
what about the imput shaft length etc? there are alot of variables to consider yeah?
does the crank have a cutout for the tip of the imput shaft to go in aswell? i've never really seen an auto box/engine before
I have not read this whole thread, but I will.
On Rb engines there is a spigot bush in the end back end of the crank shaft. When you conevrt from auto to manual you need to remove and replace the bush with the manual size one. They are just a brass bush, any machine shop could make one if needed.
Don't the SR boys cut and weld 2 bell housing together when they fit r33 Rb25 manual boxes to their SR20's?
Input shaft I have assigned money too but I wont be able to sort out until the bellhousing is done....should not be that hard(I say that now)
thanks for the input on the spigot Darrin....I am sure this will have to be made as well.
thats what i was thinking! it might be possible to add our current transfer box to the rear of the transmission?
someones done an AWD Z33 in the US. they used M35 stagea parts in it. front diff i know for sure they used. the transfer case looked familiar..........
Yeah i think it may be easier. but just alot of pissing about chasing information..
any links to this z33? it will be easier and cheaper in the end to work this way..
it is nissan afterall. surely they have used common parts somewhere here.
it mentions M35, but only the differential case
http://www.superstreetonline.com/featuredv...awd_system.html
BUT, it might help with the chopping and changing. but is it all worth the expense?
Why cannot I not use the R32/R33 bellhousing and do a spacer after to fit or even fill and reshape as the pic attached.....then it's the input shaft to mod(which will more than likely need doing anyway).
With a box designed for the VQ, you should be able to use the same starter with Z33 clutch and flywheel.
How far back is the shifter? Should be ok as they look to be the same chassis.
Also, I dont think mounting the transfer case will be as hard as telling the ecu and attessa to work with no box, too many bloody ecus talking to each other.
SAS re-flash may be able to sort that out.
May have to rip out the trans ecu though
what do you think will be easier? V35/Z33 box with a transfer case on the back, or your way?
6 of 1............
cheapest option?????? Is there a cheap option with this.....I am just trying to get out of a spec'd up Auto build for $3,500!!!!
I agree with you on the ease of the V35/Z33 gearbox......but you have the below issues:
Purchase of gearbox - My guess $2000 at least(good part about this is that it is 6 speed)
Purchase of Transfer case - Buy it with another gearbox and sell gearbox - $400 of your cost
Fitting the transfer case to the gearbox - At least $500
If the input shaft is different add $500
My way
Purchase of R33 gearbox - $900 to $1,200
Reweld for fit - $500est
Input shaft - $500est
All the other parts still have to be added to the above prices
This to me is a very doable project....lighten the car and get more HP ATW's......and get rid of the F#$King slushbox!!!!!
Defiantly agree with you Craig :D
I think the 32/33 box would be a good option. but just for ease i was thinking along the lines of finding something else..
Dont forget clutches also ;)
i'll have another chat with beau about the bell housing. unless you've found someone?
p.s. i had a puncture on the weekend. had some spare tyres from some gtr wheels i had. 215 40 17// i got them fitted without thinking on sat morning.
original 215/55/17 on the rear, and i have 215/40/17 on the front.. i had the smaller on the rear at first and was getting vibrations..
smaller on the front seems ok. but i know its going to drive the car crazy.
  • 3 months later...
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
