Cool thanks Tim,
I've actually found an SD version which I'm waiting on pricing for, out of the UK. It's listed as 199 pounds which is far cheaper than the POV1. No doubt the quality won't be as good, but for someone like me who just does the odd track day should be fine. Comes with a screen to review, mic, cam and recorder.
Before you go and spend in bulk have a look at these
Sandisk V-Mate (~$80 ebay)
Sony 1/3 ccd camera (~$90 ebay)
SD card of your choice
Cables and DC convertor
have a look here
http://www.bmsc.com.au/forums/rallying-tec...ing-system.html
Its a bit diy, but can save a wad of cash
I thought they brought it down to 100g unless mounted to floor as of 1 January 2009, but looking on the CAMS website, I can only find a document saying "NOTE FOR COMPETITORS: It is foreshadowed that from 1 January 2009, the maximum weight of any camera, lens or recording unit mounted to other than the floor shall be 100g" however cannot find anything to say its mandatory yet.
http://www.camsmanual.com.au/techdocs/T-401[1].pdf
I suspect that it is mandatory, but I can't find any reference to it yet in the new CAMS manual.
Does anyone know if something happened to force the rule change? ie camera comes loose, fly's through cabin, knocks out driver, car out of control hits wall.
Or is it CAMS being CAMS
That is an interesting question....I'd imagine that it would take a fair amount of force to break a camera away from its mounting (assuming it is a 1/2 decent mount) let alone it travelling with enough speed etc to hit a driver wearing a helmet and knock them out. In which case the car would've already been involved in an accident of some sort.
I'd say it the ol' OH&S people getting a little out of hand....
That really sucks. I just bought a camera late last year, and had a camera mount built into my cage... Not happy Jan
haha dane...doesnt built into the cage beat out bracket? otherwise just bolt it on like they've asked...or maybe it becomes part of the interior now haha
pain in the arses
A cradle should be attached to the safety cage where present by means of a clamp style bracket secured by at least two 6mm class 8.8 bolts.
• Where no safety cage is present, the cradle should be securely mounted to a substantial section of interior bodywork
  • 1 month later...
To bump up....
A question....
For those guys n gals with roll cages, what type of camera mount did you get? where from and how much?
I need one for the new nugget!
To bump up....
A question....
Check this thread out: http://www.skylinesaustralia.com/forums/Ca...l&hl=camera
I think the rule tightening came about due to the increased usage of in car cameras and video recorders now due to the relative cheapness of them and the explosion of youtube type video sharing sites.
It is an interesting thing and i have seen plenty of poorly mounted cameras in cars especially at club days and supersprints,
matt
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
