  • Replies 41
Posted Images
No reo but I will have a genuine gtr front bar and lip for sale soon if my conversion to a R33 Jun front bar works out.
Might be interested in that too!
I've been away for a few days.
The Teins are fine and would pass any inspection easily. I can post them.
The gtr guard is sold and a gtst indicator won't fit them.
Jenno call me in the afternoon when you can come that afternoon like I have told you many times. I have a lot on atm and can't plan to far ahead due to things changing.
The 26 bottom end had a cracked no6 ring land. I sold the block to a guy on here who had it machined only to find it is crack through on head bolt hole to a water jacket. His engine builder said it would still be fine for a stock motor but not for the 800hp motor he was building. No bore damage at all.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
