  • Replies 53
The thing is that it used to be in Winter ???? It was great, fast times at night etc but I think it was too cold for the girls who came dressed for the day and seemed to forget/didn't realise it would gt very cold at night....Also, it could have clashed with the Winternats....I would prefer a winter event personally.
Sheree, i loved your car;
saw it run a couple of times on sunday;
i dont usually go for that sort of paint job, but it looked awesome!
well done!
i also liked theo from street machines burn out effort;
we just went on the sunday, but had a great day in the sun on the hill with the missus watching the cars (and the ladies);
i got teh shits with the rotaries in the end (too many of em, too fast)
heh, good seeing the 4 door skyline bagging it up plenty also;
I think it was an Autech 4 door wasn't it?
I stood up and cheered after his fishy :mad: Was the only one tho... Pretty embarrassing :)
Spooks: Did you take the wrong turn off on the way there? I think I saw you up ahead of me on the way out along the Ipswich motorway then you turned off to Toowoomba... Was hoping to make a 4 Door convoy...
CONVOY!!! :)
hahah
yer, i did;
ive gone the wrong way the last couple of times :)
worked out ok though, coz that rx-7 prang held up the traffic and i came from the side through rosewood past amberly :) and skipped the traffic hold up
im sure i meant to do that!
Yes, thats right. Kier Wilson does have an OS Giken 3 Ltr kit and NO nos. I only no this because I spoke to him for a few minutes at the Jamboree.
And just to stir a few things up, I was also told that John (Munro)now uses NOS!
Originally posted by Spooks_Skyline
hahah
yer, i did;
ive gone the wrong way the last couple of times :P
only saw one other SAU Skyline Australia shirt there on the day
i was wearing mine
Yea I got to the prang about 15 - 20 minutes after it happened so I didn't hold me up too long... Looked fairly serious unfortunately... :)
I was wearing my SAU T on Sunday... Long sleeve, dark blue? Nasty little 3 year old boy in tow?? Was probably me.
Didn't see any other SAU shirts myself tho...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
