I don't know why people even bother with them? If they can bullshit you with reasons why they can't insure you, what makes you think its going to be even better with a claim?
I know Wayne got f**ked when someone reversed into him. They ruined the side indicators on the quarter panels then when his headlight got moisture in it they blamed it on age, even though the other side was fine nor was it leaking water into it before the accident. So they refused to fix it. Bullshit.
good old insurance, I moved closer to town (the dirty south = ghetto ) and it doubled the monthly cost. had to nego to get it lowered to only 20.00 a month more then aldinga beach
and value has fallen by 600 bucks without warning. but agreed value is still really high, 29,400. (shannons)
end rant. :)
time to move again...lol
someone needs to create an insurance company that does something along the lines of e.g. you only do 5,000kms a year on your car so your insurance only costs xx amount. As oposed to you have to pay a full premium every year.. it's crazy there is only a really small amount of insurance companies to insure people with imports. Surely there's plenty of people who only use their cars as weekenders (if that!) yet we still have to pay the same. They do it for nana cars so why not ours..?
you will find that shannons does insure you on your circumstances....ie if your car is a weekender then your insurance premium isnt that high....but i think that means your not covered from monday - friday....so its a big risk you take....but if you only drive it on sat and sun then shouldnt be a problem.....
yeah we do have it set up like that with shannons.. a weekender and a daily.. we thought it'd reduce it but it really didn't.. the weekender car literally does no more than 5,000 kms a yr.. it should be based on how many kms you drive it as aposed to being a 'weekender' that gets done all day sat/sun .. if that makes sense!
Edited by sare
i cannot remember who the insurance company was that had their Ad on the tv.....in regards to pay as you go or something like that.....i didnt look much into it however but it might pay for you to look a bit into that Sarah :P
they dont cover imports im pretty sure.
plus, this:
Underwriting knockout
We are unable to offer you an online quote for the following underwriting reason(s):
We do not underwrite one or more of the modifications on your car.
One of the drivers of the insured car is under 25 years of age.
We apologise for any inconvenience this may cause you.
If you think you made a mistake on the previous page, please click the "back" button and correct your answers. Please remember your Duty of Disclosure, which is outlined on the top of the first page.
Said modifications include:
* AMG
* Active Suspension - Bounce
* Air Brushed &/or Chameleon Paint
* Blow Off Valve
* Bonnet Scoop(s)
* Drop Fuel Tanks
* External Fluorescent Lighting
* Flamer Kit installed
* Lowered Suspension - Non factory fitted
* Nitrous Oxide System - NOS
* Non Standard Body Kits
* Non Standard Boost Controller
* Non Standard Carburettor
* Non Standard Engine
* Non Standard Intercooler
* Non Standard Supercharger
* Non Standard Turbocharging
* Performance Cam Shaft
* Performance Cylinder Heads/Modifications
* Performance ECU Chip
* Performance Exhaust System
* Racing Harness
* Raised Suspension - more than 50mm
* Roll Cage
* Wheel Arch Flares
* Non Standard Cold Air Intake
http://www.payasyoudrive.com.au/
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
