Wow, this got confusing. So I searched garrett official website to get the measurements of a GT2860-9 and it turns out the GT2860-7 that GCG apparently have are the same measurements as listed GT2860-9 on the garrett website.. I don't know how that works but numbers shouldn't lie.. Right?
Edit:
The gcg -7 are the following:
Inductor- 47.2
Exductor- 60.1
That sounds like a -9 ?
Edited by hazjaz
Sorry guys, it wont let me edit the above post.
After a few more hours of reading through threads on this forum I have come to the realisation that the -7s are GT2860-7 (707160-7) and the -9s are GT2859R-9 (707160-9). Going off the stats on the Garrett website, the -7 is a bigger turbo? In that case why is the -9 the one with the better performance and able to push more power easier?
GT2860-7 (707160-7)
COMPRESSOR
Ind Whl Dia(mm) - 44.60
Exd Whl Dia(mm) - 60.10
Trim - 55
A/R - 0.42
TURBO
Whl Dia(mm) - 53.90
Trim - 62
A/R - 0.64
COMPRESSOR
Ind Whl Dia(mm) - 44.50
Exd Whl Dia(mm) - 59.40
Trim - 56
A/R - 0.42
TURBO
Whl Dia(mm) -53.90
Trim - 62
A/R - 0.64
If anyone can clear this up for me that would be great, based on the read I have done -9 is the ones I want, but turns out they are actually smaller.. In which case -7 would have more potential?
Edited by hazjaz
http://www.skylinesaustralia.com/forums/topic/423175-r34-gtr-turbo-upgrade-needing-advice/#entry6811557
I know this will seem like you are going around in circles but the information has been given to you in a user friendly way.
The flow potential of the -9 is higher than the -7.
It really is this simple;
After 'response' on a 2.6 = -9 (330 rwkw or so or squeeze 350 + on E85 on a 'normal' setup) *350 plus on 98
If you can put up with a lethargic result for more top end (360-380) on a 2.6 = -5's.
Stroker = -5's
3.0 with a bulldog curve = -5's
-10's/RS's = in the bin.
*Well setup cars are the exception.
Thanks for the reply guys. I will be going for the -9s. I'm sure if I quote the model number and ask for the HKS GTSS equivalent I will be getting the right ones.
-7s seem a bit out of a waste of time unless you're chasing a replacement
Edited by hazjaz
Sorry guys, no edit button again for the above post. But after reading about the different sizes listed by garrett I went into the technical drawings and they look identical apart from the turbo outlet. Is the design of this the advantage of the -9s? Picking up the turbos tomorrow so just want to make sure 100% that I am buying the right ones.
-7
http://www.turbobygarrett.com/turbobygarrett/sites/default/files/default_images/turbogroup/drawing/Garrett_GT2860R_707160_7_new.pdf
-9
http://www.turbobygarrett.com/turbobygarrett/sites/default/files/default_images/turbogroup/drawing/Garrett_GT2859R_707160_9_780371_1_new.pdf
That's right!
-7's and -9's have the same size in specs.
From memory when speaking to Racepace, the reason why the -9's have better top end is due to the configuration of the turbine blades.
Ones longer and the other shorter (the shorter blade allowing more air to flow through).
Also to do with the pitch angle of the turbine blades.
It's at a certain degree to allow more air.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
