  • Replies 103
Poor little guys. I left some water out for the possums, the poor things were desperate.
Yeah, I feel for the poor little possums.
Although sometimes leaving water outside just invites mozzies to come and spawn in there... disturbing.
I think that's the least of our worries when we have a pool with a tiny bit of water in it ;)
I think that's the least of our worries when we have a pool with a tiny bit of water in it :domokun:
Lol.. although I thought that they couldn't stand the chlorine.
one teaspoon of keroseen (hope thats how you spell it...doubt it) and it floats ontop of the water, mozzies wont go in. so good for water tanks :P
Nice to know.
When wooden power poles self-ignite.
http://www.watoday.com.au/national/worst-d...90206-7zsa.html
I never saw them, but our premier Mr Brumby talked about them in the article... near the end. Would be cool to get a photo.
