So a while ago I stumbled across a wikipedia article listing all the nice cars a P-plater could drive. Had at least a hundred, from all different makes. I went to look for it again the other day and cannot find it any where. Don't suppose anyone has a bookmark, or know the exact title to search?
Thanks.
https://www.sau.com.au/forums/topic/255255-wikipedia-p-plate-cars/
Just use your mind, non turbo ... non supercharged ... turbo and S/c allowed on diesel ... V8 = no except diesel... over 200kw = no. Anything that isnt that is allowed except like 350z's ... some Porshe etc. Little cars like those mini Suzuki Turbos are allowed tho. Most common are like NA Skyliner, Supras and even tho i hate em to the max Commys . I looked for your list and couldnt find ><
I love you.
For some reason I thought it was on the official wikipedia.com website.
I'm still under the old system, I can drive turbocharged cars so long as they remain under the 125kw per ton rule, but I wanted to see all that was available to me.
so p platers over east still can drive the r32 gts t.
Ive never driven a r32 gts t before... are they really that slow stock?
Or is it just becuase of the Japanese and their underestimated power figures?
Edited by br3ndan
Anyone know if twin turbo GTO's are legal under the old P plate laws? They're 206kw but 1700kg which places them at around 120kw per ton.
Always loved the car personally, but I've never seen a P plater with one.
If it's under 125kW/tonne, it's legal on P-Platers under old scheme (before 1st July 2007) no matter if it's N/A or Turbo.
Cheers
Sorry to be asking this again, but I can't find anything on google, and can't be Fed signing up to a Silvia forum.
Anyone know if the SR20DET 180SX is P plate legal? It's right on 125kw per ton. Which I assume means it's really up to the cops if they want to do me on it or not. I've always loved the car, but thought due to it's lighter weight it'd be way over the legal limit.
So, anyone ever had owned a 180SX on their P's, or know anyone who has? For reference, I'd probably be getting a 96-97 type X.
Thanks.
There is talk about a R32 GTS-T that is OK for P Platers but I think if you come under the 'New' P Plater laws, cuz its turbo'd P Platers are not allowed to drive it.
There was a thread about this in the Victoria Section and I asked the question about the R32 GTS-T's.
well if it is too close to call just turn the boost down a touch and make it 124kw/t.
Nope, it's calcuated by offical power and weigh figures from car companies (nissan for this instance).
As for SR20 S13/180sx, it's grey area, there was some debate whether it is legal or not on nissansilvia.com forums, heaps of topics has been covered I believe.
Cheers
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
