Well after almost 12 months since the last one, i've just had machined 2 new billet girdles. One to suit a rwd RB and another to suit the 4wd rb30. This time it replaces the entire std girdle.
Testing will be carried out on an engine in the next 2 months.
https://www.sau.com.au/forums/topic/256351-billet-girdle/
they look the goods....but the real question......tell em the price son.
wont know exact price until i get the invoices, as soon as i know i'll post it up
Very nice work! what material did you make it from?
thanks. material is 7075
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4418153
going to be a stupid question but i want to know lol
whats the advantage of this over a stock rb30 one with a 4wd adaptor plate? (for GTR)
*puts flame suit on*
the 4wd adapter is only a 'spacer', its does not tie into the girdle to the block.
this girdle ties everything together, the block, crank and girdle
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4418640
Do you forsee any issues with the difference in themal expansion between the block and girdle?
Yes the thermal expansion rate of alloy is greater than that of cast iron, but i dont see it as a great threat to the integrity of the girdle.
When the alloy heats up, it will expand at a greater rate than that of the block, however there isnt any real where for it to expand to, it will actually give a tighter lock into the block.
This is one of the observations we'll be making with the test engine.
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4419127
i think adriano was thinking the same thing i was. My concern (possibly unfounded) is that differrent thermal expansion rates would play with bearing crush... and or centricity
Edited by URAS
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4419240
Beautiful!! :) Is there any reason you couldn't make one in steel, given a big enough lump of material? Here in the UK it's very hard to get decent line boring and honing done, they often end up a real pig's ear. How do you go on in Oz?
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4421420
Beautiful!! :( Is there any reason you couldn't make one in steel, given a big enough lump of material? Here in the UK it's very hard to get decent line boring and honing done, they often end up a real pig's ear. How do you go on in Oz?
Cost. Itd be more expensive to make one from steel due to the time required in machining. Also steel isn't all that good for dampning harmonics, and add to that the massive weight of the thing.
We dont have a problem with line boring/honing if you use the right people.
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4422122
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
