Hi all
I rang Nissan today, due to the fact that I have a faulty AFM on my R32, He said he'd get back to me.....
3hrs later he quoted me 1000.00 because they wont just sell the AFM to me.
Any thoughts?
you could get 2 z32s for a lot less than that...
Your getting your pants pulled down over the price..
Search the for sale sections. You can find them second at a FAAAR cheaper price.
Call up some Jap wreakers or Places that import half cuts. Or upgrade to Z32?
1 grand is rediculous
Edited by GTS4WD
So $1000 for them to repair your afms? That sucks. I repaired mine a couple times and got jack of it breaking down so I bought a pair of genuine afms through nissan for $1100. Expensive, i know, but i didn't want to upgrade to z32 or buy second hand. Don't understand what they mean they wont sell them to you?
I guess they are 16 - 20 yo, so they don't really want to get rid of them?
were yours for r32's?
my cousin was also quoted a similar amount for an rb20 AFM about 1 year ago. very strange.
and no Greg you dont need a SAFC or anything like that to 'tune' an afm :|
you cant run a car with a standard ecu with z32 afm
Not sure if SAFC can be made to make it work, but your standard ecu will hate the z32
Nah man Nissan will rip you off big time, just get a (300ZX) Z32 AFM from any aftermarket place afew hundred dollars as some has said on here.
I don't think you will need a tune, but you can run it on a dyno just to make sure.
Ahh k Cool guys,
Least its not only me, that fixes my theories of being cursed :D
What about airflow meter elimination with an emanage ultimate (airflow map), anybody had a shot at that?
:) Thanks for all the info BTW
Ahh k Cool guys,
Do you mean running the car with no AFM?
If so I have seen a R33 GTR with a APexi Dejectro and there is no AFM's and also SAU member DSTROY has one and you can ask him about it.
I asked about it one time and from memory it came to the conclusion that it does the same thing as having AFM's.
Or rather there was not much of an advantage, as the APexi Dejectro was monitoring the Air Flows, insted of having AFM's.
But if your having trouble finding an AFM you could use the eManage Ultimate...
Yeah i did some research on it and found that i could drop the AFM, so i was sold on the Idea hahaha.
But i did want to know if it was reliable as a daily driver still after using the map, I.e. cold starts etc.
That and in the future i was thinking of a FMIC hence the i could get it tuned.
If you wanted to retain your AFM a better way to go about it would be to get a change over item through Injectronics, http://www.injectronics.com.au/.
They send you a new AFM and if it fixes the problem you send your old one back to them.
If it doesn't fix the problem you send the new AFM back.
New units come with a 24 month warrenty and cost about $300.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
