Hi all
I rang Nissan today, due to the fact that I have a faulty AFM on my R32, He said he'd get back to me.....
3hrs later he quoted me 1000.00 because they wont just sell the AFM to me.
Any thoughts?
you could get 2 z32s for a lot less than that...
Your getting your pants pulled down over the price..
Search the for sale sections. You can find them second at a FAAAR cheaper price.
Call up some Jap wreakers or Places that import half cuts. Or upgrade to Z32?
1 grand is rediculous
Edited by GTS4WD
So $1000 for them to repair your afms? That sucks. I repaired mine a couple times and got jack of it breaking down so I bought a pair of genuine afms through nissan for $1100. Expensive, i know, but i didn't want to upgrade to z32 or buy second hand. Don't understand what they mean they wont sell them to you?
I guess they are 16 - 20 yo, so they don't really want to get rid of them?
were yours for r32's?
my cousin was also quoted a similar amount for an rb20 AFM about 1 year ago. very strange.
and no Greg you dont need a SAFC or anything like that to 'tune' an afm :|
you cant run a car with a standard ecu with z32 afm
Not sure if SAFC can be made to make it work, but your standard ecu will hate the z32
Nah man Nissan will rip you off big time, just get a (300ZX) Z32 AFM from any aftermarket place afew hundred dollars as some has said on here.
I don't think you will need a tune, but you can run it on a dyno just to make sure.
Ahh k Cool guys,
Least its not only me, that fixes my theories of being cursed :D
What about airflow meter elimination with an emanage ultimate (airflow map), anybody had a shot at that?
:) Thanks for all the info BTW
Ahh k Cool guys,
Do you mean running the car with no AFM?
If so I have seen a R33 GTR with a APexi Dejectro and there is no AFM's and also SAU member DSTROY has one and you can ask him about it.
I asked about it one time and from memory it came to the conclusion that it does the same thing as having AFM's.
Or rather there was not much of an advantage, as the APexi Dejectro was monitoring the Air Flows, insted of having AFM's.
But if your having trouble finding an AFM you could use the eManage Ultimate...
Yeah i did some research on it and found that i could drop the AFM, so i was sold on the Idea hahaha.
But i did want to know if it was reliable as a daily driver still after using the map, I.e. cold starts etc.
That and in the future i was thinking of a FMIC hence the i could get it tuned.
If you wanted to retain your AFM a better way to go about it would be to get a change over item through Injectronics, http://www.injectronics.com.au/.
They send you a new AFM and if it fixes the problem you send your old one back to them.
If it doesn't fix the problem you send the new AFM back.
New units come with a 24 month warrenty and cost about $300.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
