Damian at Grafico.
grafico.net.au
he does all the stickers for the supercarclub (p1) and did all our Dutton Stickers and the 6 hour stickers. His stuff is quality.
there is an asian dude at Carribian market
I use CarX for all my vinyl graphics. Call Kevin on 0422 127 847
He uses quality 5 year vinyl.
65 Whiteside Rd,
Clayton South, VIC
you guys are the best thanks for the quick help. any you blokes racing the haunted hill hillclimb??
hey crew anyone know where to get large custom made stickers? looking for something to put on my van have a design need someone who can print it up or make me a vinyl. cheers
Send me a PM, I can help you with vinyl graphics but don't do any printing. Some of the smaller vinyl graphics examples at jdmstyledecals.com.
there was a euro looking dude, also a bogan looking dude at one stage. but last i went there only the asian guy with his sun, and the GTR badges and so forth
LOL! You mean his Son... Yeah I do remember that, had all the APexi, BLITZ, GReddy, HKS and cheap fake badges.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
