  • Replies 2k
Your probably right, but the specs as I quoted them for the L20ET are right.
I just transfered all my L20ET bits onto an L24E with the FJ20 turbo and it's heaps different in size (rear housing)
what ecu are you using, and is she alive??
The L20ET one & Yes it is!
Don't have a choice, only L series turbo ECU I have.
As I said before L24E ones are good for landfil.
Why? you offering an alternative?? :ghost:
no, unless you want to look at a wolf3d?? it's just i have all the bits sitting here to do the L24et thing but not the time..was going to spruce up the MR30 hatch with the turbo gear and sell it.. would there have been a different ECU for the L28et engine?
FJ20's came with T28s and T3s.RB20's are T28s,and RB25s are more of a T3.
I had the stock L20ET ECU running my L24ET,and believe me,they're over fueled enough to run a 3L!!!!
can i ask how the L24et went? also with the rb20's was there any difference from red top to silver top with the turbo mounts?
Very nice round town.I had a worked 3 spd auto behind it,with VL stall.Very "zippy" for lack of a better word.Hit the loud pedal,and she was back a gear and of you'd go.Top end wasn't huge,but everything else was pretty much stock,7psi,and no intercooler,so I thought it was pretty respectable.
Got 15.1 (and 96mph?) on G-tech,but most of that was cause of the launches!
Stand on the brakes and the throttle,get 5 psi on the dial,then hop off the brakes and you're in squat heaven! :O
Stand on the brakes and the throttle,get 5 psi on the dial,then hop off the brakes and you're in squat heaven! :)
That's pretty interesting, my L24ET will also be non intercooled but with L20ET ECU, but trying a L24E AFM and maybe throttle body, depending on which is the larger plus the T3 FJ20DET turbo and 5 speed man transmission.
Should make an interesting gadget to sell, as my MR30 hatch is a fully optioned Ti with the addition of the PNV interior, & grey dash.
Surely it will be a one off, RED with Grey/Black interior. All OZ delivered reds were brown interior.
As a matter of interest! does anyone know the differences of L series 6 cylinder engines?
Is their hieghts the same or does it increase as the capacity increases?
How far can the L20 be stretched etc, etc.
hey, i think you would find that information on one of the "Z car" websites. The yanks are really into the big "L" series motors. L28.
anyhow, my dad found a really interesting program on the net. it showed what could be done, by mixing the parts from all of the "L" seies motors. (Showed, bore, stroke, compression etc.)
Ill find it and make an attachment soon.
well, spose you drive a v8 commodore or something.
Cos only cheap wine comes in 5 litres. :)
That's well put Mick, but all these dicks have a different thing to say when the 2L is kickin the 5L's ass.
I had a 1750cc Hillman Hunter years ago and on the way back from the snow at 125mph a 5L SLE C'dore couldn't go past me. Could catch and sit on my rear in my slipstream, but when he pulled out to go past, he went backwards.
I only had 165 HP at the fly.
Re that program, PHaT in Tassie has the same I think, but I will do a google search and see what it produces.
Tah :ghost:
just got the HPI DVD #8 and theres a small bit of R30 action at the drags :aroused: mate it was brillant, dos'ent tell you much about the engine set ups but they were putting down mid 11's one got into the 10's :wassup: all running fj's, just for that part alone it was money well spent i give it 3 thumbs up...
theres a BIG (50+ cars)skyline cruise tonight hopefully as its rainning at the moment but i've been to a few in my r31 and there great!!
Is the any wreckers that anyone knows of who have interior pieces such as air vents and side mirror covers for the R30??
what colour interior do you have as i have a mr30 sitting here with baby sh%t brown interior?? side mirror covers are black ofcouse..
Re R30 Fronts!
I have come to the conclusion, after studying both for most of today, If you want to use the Tekamon bonnet with stock headlights, a modified (cut down) stock grille would have to be used, primarily due to the impossible task to remove the chrome trim from under the headlights. To keep uniformity, the cut down stock grille would have to be used.
The Tekamon front was designed to improve aerodynamics, so if the plan is to have a quick car the Tekamon front would be the obvious choice, but if show is more your go, then the stock front is probasbly best.
I will post pics in due course
Or to put another slant on it,just for discussion sake,cause I'm bored,if you stuffed an RB series 6 in there,the stock style front would be better for cooling,as it would allow more air flow to the radiator,as the bay's are pretty full with an RB in there,and hold a bit of heat.
I guess you could also say the same for a big front mounted intercooler...
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
