  • Replies 2k
']i have a DR30.
yeh the diagrams on FJ20.com are the 2 that are no good. its a 2 page diagram of the ECU wiring. i need the full wiring diagram with fuel pump etc on it.
OK,first thing you must have is a test light.If you had a burning smell first check all your fusible links(on mine there is 3 at the battery and 4 at the fuse box)
The fuse box (drivers side firewall) contains all your fuses and relays including your fuel pump relay.If all your fuses/fusible links are ok you should have power to all the relays and the fuel pump relay should click off after a few seconds with ignition on.If all is ok connect your test light to the fuel pump and with ignition on or engine cranking you should have power to the pump.
Try that and see where you end up.
Todd
Yeah I was thinking today that I want to be able to see the screen easily as I'll use the speedo function (will calibrate with a GPS) so I might put it on top of the steering column inside a tek box so it looks like a Jaycar digital speedo.
Does anyone know how that annoying 114kmh beeper works? Does it just get a signal from the ecu when the car exceeds 114, or does it recieve the speed signal?
whats the device that makes the beeping noise?? is it standard or after market?
ADAM,I'm not sure if it runs off actual speed,or just an ecu output,as you say.At a guess,I'd say it runs off the speed sensor wire,the units in HR31's do....
What I am sure of,is if you want to compleatly remove the whole 'ding' module,and stick it in a postpack I'd be more than happy to shout you a couple of beers :rant: or send it $10 COD.... I WANT ONE!!!!!!
What I am sure of,is if you want to compleatly remove the whole 'ding' module,and stick it in a postpack I'd be more than happy to shout you a couple of beers :P or send it $10 COD.... I WANT ONE!!!!!!
I may have a spare one lying around, ill get back to you on that one
My mate has an S13 180SX and he can't change the sensor, but the beeper itself simply attaches to the back of the speedo by 2 screws.
He removed the beeper/speaker and NO MORE NOISE, but you have to put the screws back, something to do with open circuits, as others have removed the beeper, left the screws out and had problems with the speedo fluctuating.
well i went outside today to my car to pull the dash apart and look for any burnt wires but decided before doing that id open the fuse box and turn ignition and listen for any of the relays ticking over to try and find fuel pump relay.
anyway, turned the key and *bzzzt* pump was back to life. power was back to it again. i then turned it on and it was super lumpy and rough. checked the pressure guage and it was reading 41psi idle pressure rather than the 34psi i set it to the day before before it died. then found out that the guage, rather than sitting on zero, was actually sitting another 1/4 of the guage face further down, below the vacuum area (guage had vacuum bit on the bottom 1/4 of it). so it was probably about 15psi out or so :P so wen i connected it initially and thought it was at 19psi, it was probably at 34psi like i wanted. and then wen i turned it up to 34psi, it was more like 50psi idle pressure. so wen i took it for the 2 spins round the block, it must have just overloaded the system and thats y the wires were burning. ECU must have noticed and cut the power to the pump at this point i guess.
so i connected another guage, disconnected the 2nd air valve thing that i had hooked up yesterday when it was at the wrong higher pressure, and got some new plugs since the old ones were all fouled up, and it sat and idled perfectly at 34psi idle pressure.
so just gota take it for a drive tomorow and see how it goes, see if it still has the huge misfire that it had and if it starts to get too hot and short the wires again. hopefully no permanent damage was done but we'll see tomorow i guess!
Its located underneath where the head unit goes in the '30s I think.  If it gets a feed from the speed sensor wire then that would be quite useful
Its to the right of the cig lighter, those three lines/slots in the plastic allow the noise to come through, is a little metal box behind the slots.
Oh tell u what got a surprise the other night, opened the fridge to get some mayo out and the bottle behind it had a familiar face on it!
It was baltic or balsamic vinegar and it was Paul Newmans own brand!!!
sorry totally off topic and random, just surprised me and Ghostriders signature trigger me
was driving home this morning from a mates place and saw an all black hr30 2door driving the other way, big ass fmic taking up the whole front centre, sounded rotoraryish big on lumpy noise, turned around to try to flag him down but lost him?? so looks like these another 2door r30 on the coast, about bloody time...just have to track him down...
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
