  • Replies 2k
Ok,no one discuss it with me then! :goddam:
:cheers:
Adam,I'm going to try some of that Redline Shockproof in my gearbox and diff next change...
As for the front: After much deliberation, if the new air dam is to be used, the tekamon front is the go, but if staying basically stock, I think the tekamon bonnet would look best with modified stock grille and stock headlights.
For Oil: I use 75W/90 Mobil full synthetic in both LSD & Gearbox
YES
I agree with you :D
Hmmm... 75/90... cool
I swear my diff isnt standard... on the way to a friends place in the hills last night, going up a set of very sharp hairpins on a slope, was in second, lowish revs, once I turn the front wheels a certain amount the diff sort of locks and the inside wheel chirps. I've noticed it when I've done sharp rolling u turns (little or no power on) and its chirped then too
Is that normal?
The car came from Japan with a few bits like the Watanabes, adjustable suspension, 3 inch exhaust, momo wheel, Jenesis (I think) front bar with offset plate and a huge GT wing
My car also chirps in 2nd gear quite easy.....maybe all R200 diffs are like it???
Redline oil is the way to go, it does wonders for notchy as hell toyota boxes, I'm bout to try some in my car...... I'll let you know how it goes!
Does anyone else get this problem on a semi-standard FJ20 box....... for example, coming to a red light, shift out of gear into neutral and coast up to the lights, when it comes time to go again, 1st is a mofo to engage!!! Anyone had similar problems or know what it is???
The engagement problem can be said for many makes and models as ease of selection depends entirely on the alignment of the gears at the stationary position. If it doesn't go into first easy, take second, then first and it should go in easy, second time around.
with my front i have a relativly large cooler sitting infront of the radiator, the 2 slits at the front feed air to the radiator as the fmic sits rather low (for that perposs) i also raised the bonnet using washers about 10-13mm at the hindges to get a little more air flow through the engine bay...
Hey all, has anyone in here modified their Aussie R30?
Im planning on getting extractors and a custom 2 1/2 inch. exhaust made soon.
has anyone done this? if so, how much difference did it make?
I already have a K&N panel filter in a modified air box. Also, does anyone have a manual R30 that they want to sell chaep?
I just want the necicary parts to convert my auto to manual.
and, does anyone have a R30 wagon that they are wrecking? I want the disc brake rear.
And finaly, i want some Jap spec taillights, anyone have any for sale?
Guest
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
