HEY everyone,
Mark from HPI mag here.... just wishing to let you all know that, 999 automotive have just recieved a container loaded with some skunk 2 plenum spacer kits....
this is a simple bolt on mod that adds more more airflow and can add an extra 10hp
they are worth about $360....
Give the guys at 999 autmotive a call, let them know that Mark from Hpi told you about them, and i am sure they will you guys a good price.....
here is a link to a video file,..... im getting my installed next week.... i will let you all know how i go...
http://www.metacafe.com/watch/1378321/skun...version_2_tech/
https://www.sau.com.au/forums/topic/257972-skunk-2-plenum-spacer-kit/
  • Replies 44
I'm more interested in the full plenum replacements such as Kinetix and I think the other was an SSR as seen in HPI
Cheers
Geoff
Yeah I put a Kinetex one on my car a couple of weeks ago, pretty happy with the result. On the downside it's wasn't that cheap with the crap aussie dollar, the engine cover didn't go back on as the holes must have been in the spots for a 350Z cover or something and there is slightly more engine noise as you don't have that fat lump of metal sitting on top of the engine, still quite acceptable just not *quite* as refined. In the end if you're not looking to blow thousands but want a noticable little increase, it's worthwhile.
For sure mate. :D Just get them to call me 07-3272 9992.
Cheers,
Adam
I've linked this to some guys from 350Z Tech who were looking for plenum spacers locally, so you might get a few blow-ins from there.
If you can offer them a discount, I'm sure they'd appreciate it. :)
Adam,
The plenum spacer kit arrived in the post yesterday. I won't have a chance to fit it for about a week as I'm off to site, but thanks for the prompt and professional service :D
No worries mate. Please post the feedback here to let all the members know of this product.
Cheers,
Adam
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
