  • Replies 285
ok ill actually bite on this one...
rb20 has 3000rpm of useable boost and rb30 has only 2400rpm!!! RB20 WINS!!!
if you actually have a look at both your graphs you would actually find that the rb20 would turn out to be faster motor for the car
good graphs to compare rb26 vs rb30 are busters rb30 with 51kai and mine or r32gts rb26's with t04z, all are making similar power with very similar rev/power bands
the 30 would have loads more midrange though, and itd carry that peak power (or similar) right to redline. so say redline on the 20 was 7500 and on the 30 it was also 7500, the 20 would only have a peak power band of 1000rpm, whereas the 30 would have a peak powerband of 2900rpm
i dont understand the way ur thinking about that
RB20 170rwhp+ between 4700-7700rpm = 3000rpm
RB30 170rwhp+ between 3500-6000rpm= 2500rpm
we will call that a win to the RB20
RB20 230rwhp+ between 5750-7500rpm = 1750rpm
RB30 230rwhp+ between 4400-5800rpm = 1400rpm
another win to the mighty short stroke machine
and dont give me the sh1t about the rb30 will last longer because of the revs bullshit, a rb20 will never die haha
Edited by Cerbera
I was thinking similar re: RB30/20
Ah ye but by half the arguments in this thing, if your never below 3500rpm then why the need for power below it?
Not that i neccesarily agree, but it goes against what a few others have been saying so far here.
Not sure how its a peak power band though, the torque would be dropping off, how much depends...
Its all argumentative of course :bunny:
The RB30 only gets revved to 5500-6000rpm at the moment as the turbo is WAY too small, that's still at least 3000rpm of usable power..
Limiter is set to 6800rpm but never gets hit as the power drops off rather dramatically after 5800rpmish :(
It was a direct comparison between spool and peak power.. anything else is pointless because the turbo is so undersized for the engine. If the turbo was big enough to let me reach redline then the RB30 would win in your above comparisons.
GT35R will be on soon.. unfortunately I don't have an RB20 that I can strap it to aswell and do some more testing :bunny:
Oh and an RB20 will die.. didn't adams' die? yes it lasted quite some time making the power it did! but it still died! :) but anything will die with enough abuse..
P.S. yes the RB20 was faster (due to not being able to wind it out in each gear) but that was countered by making use of the extra torque with some 3.9 gears. The RB30 is an alround nicer engine to drive on the street though.
P.P.S. the 30 is also a LOT better for big smokey burnouts, which is afterall, the most important thing :D
Edited by bubba
Pfft RB20's don't die, what a load of shit.
I can gauarntee if the RB30DET was available from factory in a GTR half of these arguments wouldn't exist. It's just the fact it's in a VL which puts people off (and i dont blame them, it puts me off aswell, however i can look past that and look at a block for what it is...a BLOCK! There is more to an engine than just the block).
Hell if half you people are so against saying "you have a RB30 under the bonnet", simple fix, don't tell people. Not many people can notice the extra height in the engine bay, so for all they know, you have a huge HP RB25/RB26.
It would be interesting to see whether some one that was so "RB26 pure" could actually tell if a car was a RB30/26. I could bet they wouldn't and would probably just say "Wow this thing has a lot more torque/response than mine!"
Not saying you can't build a RB26 to have as much torque, not at all, Dirt has proved this, however look how much experience he has and how much time and money he would have put into development. For 90% of engine builders around the country, they couldn't come close to potential of a RB30DET.
My 2 cents.
Edited by PM-R33
i know the turbo is too small for the dirty 30 but you brought it up as a example, i was just showing that capacity isnt always the be all and end all of the argument
the most impressive graph i have seen from a rb30det is al's 3076r which is very impressive, nothing else has really tickled my pickle as you can always find a rb26 making similar torque/power but with only 86% of the capacity
dont get me wrong 30's are great but they should be 15% better than 26's :)
this has bene said alot lately but i'll say it again. the head makes the power, so u cant really fairly compare a std head with a modified head
Great post Shane....
Example, our RB26 had a torque curve like an upside-down ice cream cone once we went from 2530's to GT-RS's...not even 9500rpm off the limiter launches would stop it from bogging and being a pig to race. Do you think that if we bolted on an RB30 bottom end it would have fixed it...no way.
Soon as we did the head it transformed it into a car that had a big flat torque curve from a peak at 4500rpm all the way to the 9500rpm redline.
Same thing happened with another car is was involved with that used the same style head as mine...it moved the whole torque curve 1000rpm earlier and kept it flat in the top-end without falling off.
There's more to these engines than simply bolting on a bigger bottom end.
Edited by DiRTgarage
I've never seen an rb26 get near the torque of an rb30 on the dyno I run on and there has been a a lot of rb30's and rb25s on that dyno running upwards of 500rwkw.
Regardless. A dyno sheet doesn't reflect the throttle response, drive ability and power produced in the lower gears. Its like night and day and I would say so more so than 15%.
The larger motor spools the turbo easier in the lower less loaded faster reving gears.
More boost is made combined with the additional displacement and the motor feels like its making considerably more than 15% power compared to the rb25 in the same low gear.
Get in to a well sorted rb30 (head cams etc) and similar sorted rb25/26 and youll realise how little dyno sheet comparisons mean when looking at different capacities and gearing etc.
Obviously as Dirt stated you can't just bolt on a bottom end and hope for the best. It must be well sorted otherwise rpm will suffer.
Edited by TheRogue
dont get me wrong 30's are great but they should be 15% better than 26's :down:
Is that similar PEAK torque and power or average peak torque and power.
No capacity is not the be all and end all, but volumetric efficiency is so if your playing with a larger volume then all else being equal the larger engine will produce a higher average and overall power and torque figure.
Doesn't really matter as this is a pointless "horse for a course" argument really. :)
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
