  • Replies 73
Originally posted by JimX
Two stock turbos will be able to be provide more boost to one engine because they're only feeding half the engine....
But they are feeding a common plenum chamber. The laws of physics dictate that the pressure will be distributed evenly throughout the induction system. Therefore you can only run boost equivalent to the lesser of the 2 turbos. So if you're running 9psi on each turbo, you can only run 9psi at the wastegates, and therefore 9psi at the valves. If you are running 18psi on each (ceramic) turbo, you are flirting with danger.
Hi stimps, "You can run 18psi with one of these turbos"
We ran 12 psi on an low K's R34 RB25DET turbo for 8 minutes and it did the usual ceramic turbine thing. I have 10 other examples on various RB20/25's, you are the exception not the rule.
"by having the right intercooler and tuning"
Firstly it is the combination of heat and resistance that causes the ceramic turbine to fail, not just resistance. Is is simple physics, turn the boost up and you have to retard the ignition timing otherwise it pings. When you retard the ignition timing, the spark fires later in the combustion stroke. Therefore combustion takes place later, such that at higher rpm the exhaust valve opens before the combustion is all finished and some actually takes place in the exhaust manifold and turbo. Bingo extra heat on the ceramic turbine. The more boost, the more retarded the ignition, the more combustion in the turbo, the more heat.
Add that to a few hard laps of the circuit or a long hard run on the freeway or drag strip and you will be picking turbine bits out of the cat.
Anyway, that's been my experience and 10 others I have fixed. Roll the dice if you like.
While I'm at it, "478kw at the wheels with a stock bottom end R33"
I could make a 1,000 bhp out of a standard RB25DET bottom end, on Elf Turbomax, shoot that's easy. But for how long, 22 seconds while I do 1 Shootout mode power run on the dyno?
Me, I like to drive my car at full power every day, whenever I like, rain, hail or shine, on the track, road or circuit. Fill it up at the local BP and I'm away.
Hope that explains my thoughts.
Hi stimps....
"is that with a stock cooler? "
no, HKS in a couple, GTR in a couple more, GReddy in 3, and a couple of locals - Micks Metalcraft and Performance Metalcraft. No Standards.
The JMS 478KW car.. Is that the one that boiled its brains out recently at Gawler?? I understand it blew the head gasket and split the cylinder head... and when they pulled the head of it had severe detonation on the piston crowns, and suspected broken ringlands. Or maybe that was another of their cars they pushed beyond the limit.......
The problem is heat in the exhaust, not heat in the inlet. The intercooler is irrellevant in this scenario. More boost at the engine = more retarded ignition = more heat in the exhaust.
Remember, it is not how hard you push it, but how long you push it.
Hey Sydneykid, don't want to start a "dynos runs and rwkW don't mean a thing, dynos are only good for tuning" argument, but just curious what the RB31det in your R32 makes? No other motives, just plain curious what a long stroke monster will make
The JMS R33 was running around the 350rwkw mark at the Drift Day.
I wondered if the motor had died as on its last couple of laps due to it bouncing off the rev limiter constantly I saw smoke emitting from the exhaust.
My Small RB20 turbo has been pretty good to me running 16psi since I got the FMIC around 1.5yrs ago.
Its not so much how much a long stroke motor will make its about where it makes it.
After looking at my RB30 block compared to a 250 Ford 6 motor the RB30 looks very small.
Hey Ronin09. There are 5 RB31's in the current batch. For curcuit racing, we have found anything more than 650BHP is actually slower, so we will be limiting the curuit engine to a very responsive 625BHP. One of them is going in a drag car, with twin 3037's, so it shgould comfortably make more than 1000BHP.
So it is really a matter of what you hang off the engine, as the internals have quite a large spread of horsepower potential.
Hope that answers the question.
Originally posted by stimps
oh, and japanese motorsport in sydney got 478kw at the wheels with a stock bottom end R33 so use that as a bit of benchmark when it comes to how strong the motor is. (in other words, bloody strong)
Just thought I would give JMS a call - they do not have a shop in sydney.
I would appear stimps you are either very confused or full of shit.
Either way I think it is a good idea to get stuff right before you start to post up making claims.
There is enough dis-information around already, adding to it doesnt help.
A warning to others that may listen too long or hard to your comments.
they must of shipped it to adelaide???? the car was built in adelaide, and resides in adeliade as does the owner, Danny Vahoumis, who is also the proprietor of JMS. The car travelled to sydney once, but that is a completely different story.
Also the car made 448rwkw, not 478rwkw.
You really should get things straight before you sprout them as truth - otherwise, as stated before, all you do is add to confusion and the already huge amount of disinformation on the net which helps no one.
Plus you have just shot your credibility to pieces on here.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
