My understanding may be incorrect, but I would think the HIGHER your HP, the MORE difference lighter wheels will make.
To take your example, if a 40fwkw civic changes to rims half the weight, then the drivetrain loss associated with driving those wheels is halved as a percentage (obviously the flywheel, transmission aspect hasn't changed). They may then appear to "gain" a few fwkw.
In your car, halving the weight of the rims will again halve, as a percentage, the drivetrain loss associated with turning the wheels, but as you have 10X more power than the civic, the effect will be magnified in terms of power-to-the-ground "kw gained".
Not to mention that lighter wheels are:
- easier to acc/decel/stop
- easier to steer
- provide better contact with the ground (read the above thread)
- give you kudos!
But then again, you have spent 40k to make a 375rwkw car - more than many GTRs (and probably ended up being similar price). Why exactly do you need more? Do you spend a lot of time on the track? If it's the street, then you won't notice much difference, as you will very quickly overspeed without any effort no matter what wheels you hve.
  • Replies 48
- easier to steer
- give you kudos!
What do you mean by "you will very quickly overspeed without any effort no matter what wheels you hve"?
Yes it's JUST for the street and maybe an occasionall straight line quater mile.
I just performed a simple test today, I went to the gym, placed a 15 KG weight on the bar, and a 10kg weight on the other side of the bar. I spun both with my hand, and I can honestly say their was not much difference, and bear in mind, this was with my hand, not with a 375 rwkw engine spinning the wheels....
I just asked nengun, they told me their nismo LT GT4s weigh 11 kg rear and 10 on the front.
Is it worth paying an extra $2,500 for a wheels that are 4-5 kg lighter AND without tyres? Have a think about it.
10-11kg sounds wrong to me....
As for the tyre comment, all wheels are useless without tyres anyway, so the end result will still be Xkg heavier if the same tyres are used on both sets of rims..
In all honesty, on acceleration you wont notice a huge difference as you have that much power driving them. Where you will notice the difference is in steering response, ride quality and braking performance (were all that power counts for nothing).
Also if you want traction i think the tyres are going to cost more then the rims :/
$2500 more expensive? Pffffft. Shop around and you'll find some quality Jap wheels at a good price, there's some 2nd wheels in perfect condition if you look. I got a set of 17x9.5 +12 Volk TE37 with 4 Dunlop semi slick tyres for $3000 recently, all in awesome condition! I think they weigh around 7.5 kg a wheel
I would much rather pay a bit extra for some quality, STRONG wheels that actually come in decent offsets, unlike those Starcorp wheels that only come in ghey offsets and would probably buckle if hit a decent sized pot hole...
Your 16-17kg wheels without tyres weigh almost as much as 32gtr wheels with tyres! Try to remember with bigger wheels the increase in weight hits you harder, inertia is a function of the distance squared.. I can certainly tell the difference when I switch between my 16" 32gtr and 18" ssr professors and thats with over 400rwkw.
You should be able to pickup some decent jap wheels for around 2k - and if you sell your stock wheels that'l get you the extra 500 you need.
"ghey" offsets? These wheels were designed to be used on the R33 GTS vehicles....
try this: put 15 on one side, 5 on the other, get both spinning real good, then try to STOP them spinning. come back and tell us which i harder to stop.
with your power, getting them going wont be a problem. but like someone said before, braking doesnt take killawasps
the starcorps are awesome. buy those. you won't notice it.
*this is what you want to hear. so far everyone has advised you not to buy them, but deep down you know you want to. just ignore the other posts and buy them.
Everyone....? Go back and read the thread again. :P
Anyway, it's too late, I just purchased the Lenso D1R Hyper Silver wheels in 18x8.5 +35 and 18x9 +32 deep dish for my R33 GTS-T.
I had the shop measure them up on a scale, and they turned out to be between 11 - 12 KG.
Considering nengun informed me their Nismo LM-GT4 wheels weigh in at 9 and 10kg respectively, I thought this was pretty damn good!!!
Thread can be closed now, thanks for all your opinions fellas, you kept me away from the nasty heavy star corps, 16 kgs is alot......
Cheerio :wave:
if you are getting the D1R's get better offsets....
18X9+15
18x10+22
would fit with a lil bit of work
Are u kiddin? 18 x 10 +22? That'll stick out worse than my dog's balls when he hasn't shagged for like 2 weeks.
My car is lowered, I still want to keep the tyre under the guard while having reasonable camber.......
Yes, i did indeed say ghey offsets. Anything over 30+ is a joke really if you want it to look good without using spacers.
...and this is the reason that majority of Aussie modified cars fail hard. You could easily fit these rims under the car with minimal guard work and -1 deg negative camber.
You're a clueless gitt...... I belielive looking good is down to personal opinion, some people like having +40 offset, others like having +15..
As I said before, those starcorp impuls were DESIGNED to fit the r33 GST vehicles, so no, they are not "ghey" offsets, they are what it should be.
I'd like to see you fit 18x10 +22 on the rear of an r33 (thats lowered) with "minimal" guard work and -1 neg camber... Someone one here PLEASE prove me wrong...
Actually, yeah they would fit....... if your car isn't lowered beyond the point where the wheel goes under the guard...
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
