  • Replies 181
lol Paul will be flying at like 100ks to a corner, matt is freaking out paul replies with confidence " hey bro relax, let the computer graphics do all the work"
Hahaha...
Or he forgets he's in a GT-t...
thats awesome. congrats Matt.
now just get Paul to sign you car and take a pic of him signin it and it will be worth billions lol
main selling point"signed by and escorted Paul Walker" lol
Is there any chance Paul can sign my genuine "Motec Exhuast"???
can i sit in the boot matt?
This can work wonders for you buddy... time to advertise what the car will be doing... companys will contact you and you will get quite a bit of money for trackdays/mods etc.. haha :sweat:
not to mention Ray will be getting free advertising lol
not to mention a flod of phone calls after they see the detail in his car in the HPI no.105
the web designer better get cracking and get their webpage up and running .. think patrick of these forums is doing it
Andrew - can you drop me an email???
[email protected]
Or call me if you still have my number. Wanna have a chat about some things :)
Cheers dude
Ash
Its too late to submit pics of the 31 Ash, the choice has been made! :)
Well done Matt :P
haha the website design is done! Im too lazy busy to write the content, that's Ray's job :D
Some of us should go to the premier and support Matt! And take photos/videos! FNF stars in SAUVic cars FTW.
lol we shoud. go down in a massive convey. skylines parked on both sides of the streets. what more could you want for an opening night :P
when is the big night anyways???
Its too late to submit pics of the 31 Ash, the choice has been made! :P
lol - nah i met Andrew a long time ago...
Looks like we might have some interesting things possibly worked out for Vic Members :(
i'll probably get NOS inquiries
I'll need a motec exhaust, stand alone fuel management system, enough NOS to blow myself to pieces, overnight parts from Japan, and a floor pan - which will not fall off if I have danger to manifold.... :P
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
