Result from R33 21U high flowed turbocharger:
R34 GTT RB25DET NEO unopened engine.
- Power FC
- 1000CC ID injectors
- Factory cams, cams gears, and all manifolds.
- HyperGear R33 GTST 21U OEM High flowed turbocharger
- 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 4 inches induction pipe
- Split fire coil packs
- 600x300x76mm front mount cooler
- Tuned by Trent Hewitson, Chequered Tuning.
312rwkws @ 19psi E85 fuel
Imagine if they could maintain that initial smooth steep power curve increase as the boost comes on haha
Stao, do you do the option to supply the rears ceramic coated once ordered?
I don't have the machine to do that. There is a workshop not far away that does ceramic coating, I think they charge around $100 a housing.
Another result to post. ATR43SS2 externally gated. This is the older version.
Usual 3 inches induction and exhaust, FMIC 600x300x75, 1000cc injectors, high mount, 45mm external gate, PFC E85 fue.
<script pagespeed_no_defer="">(function(){var g=this,h=function(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};var l=function(b){var d=b.length;if(0=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.sau.com.au/forums/index.php?s=b9c74eaa9e8468f815fb75ce17859f73&app=forums&module=ajax§ion=topics&do=quote&t=261613&p=7654228&md5check=b49b7836ac70550ba950be58aabf0e55&isRte=1,6YgIICLrb3,true,false,Xk_isDeHn4U');</script>power.JPG&&0){for(var>
Hey Tao, its actually got 4inch intake, 4inch striaght through exhaust, 600x300x100mm cooler,50mm gate
Stao, How do you work it so the aircon drain pipe doesn't sit against the dump pipe? The flange on the rear of the turbo is so huge it pushes it all back and its melted my aircon drain pipe.
Any videos boostn looks brutal on paper what size dump pipe
Yeah was about to put a couple up now for you to see, the combo works really well, dump is 3 inch. Will put the link up soon when I get on the comp.
That would be awesome do you think the 3" dump could be bit of a restriction
With a 50mm gate to atmo I dont think its a restriction but if was plumped back then would be.
here are a couple of vids
https://www.facebook.com/video.php?v=10204787985648996&pnref=story
https://www.facebook.com/#!/video.php?v=10204742413869730&pnref=story
Edited by boostn0199
Checked them vids out very cool it comes on supper early real nice setup would love to have that response you have there.
Are u running metal hg and studs ?
Just a stock headgasket and std headbolts.
Stao.
Sorry if you've covered this already.
So you can get either the standard high flow for $850 with the line etc or the new model highfliow for $990 (the extra cost covers different internals and a high pressure actuator?)
So the r33 high flow on an r34 should do up to around 310rwkw with the right mods,
With E85 and Greddy return flow cooler what do you think it will max out at?
To put the non return flow cooler in did you have to cut out part of the battery tray (and cut the hole)?
Big responsive numbers from the high flow. Would like the response it offers
Good day, Yes the new actuator opens the waste gate bunk to 90 degrees. Which is included in the $990 option.
You will need E85 to get 310rwkws using a R33 high flow on a R34.
I'm usually seeing around 245rwkws with the return flow cooler, on E85 it is expected to reach 270rwkws.
To use PWR cooler or some thing in a 100mm front mount, you do need to cut under the battery tray.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
