Hi Gargus. Yes I ended up making a gig and mount every single housing to it before machinery work. It turned out in identical shape and spacing to the stock turbine housing. I fitted one to my own R33, went in all easy no problems at all. I also tried to boost it up and down with a EBC. Went up to 20psi no worries and also holds on 7psi no worries. I'm currently running on 7psi with all stock gears. pulled harder then stock turbo running 14psi.
Depends on what it is and parts availability. Roughly 3 to 5 working days to have the turbo built before dispatch.
Awesome. Are you able to tell me, if mine has been dispatched yet?
so what is the best choice for 400rwhp.. external gate.. and i dont want to run anymore then 20psi on pump fuel, i want a turbo that will give me 120mph at the strip....
That would be a ATR45 in .82 turbine with .70 Comp. Its rated to 600HP we can build that in sleeve bearing for $1400 or Ball bearing using GT3582R CHRA for $1800.
Hi Stao, did you end up tuning that R33 at Status today? if so how did you go with the waste gate actuators? im thinking maybe going for a 14psi 1 straight up and seeing what that does to mine. tell me what u think.
regards
Chris
my injectors didn't arrive till late this afternoon so my tune was rescheduled till Wednesday. I had a play with my EBC using the 14psi actuator. I can rise it any where form 13psi and above, not below. I will post some sheets once I get it all tuned and running on Wednesday night.
standard high flow is $880 with oil line. That should get you around 235rwkws max.
We can also do a 250rwkws high flow based on your stock housings which will cost you $1000 with oil line and 14psi actuator.
This is Part 1 footage of our 344rwkws ATR28G4 (ATR43G3) S13 drift car at winton last month. Enjoy:
I will upload part 2 and part 3 tomorrow.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
