why are people running these turbos at 17-18psi and not 22psi?? Whats the go with the dude above asking for a 14psi actuator, why not a 22psi one?? confused...:unsure:
The headgasket, the combustion pressure, the heat. Alot of issues come in when running high boost. I don't think the standard headgasket is good for much above 18psi for too long, especially on 15+ year old motors. You are really gonna start increasing the intake air charge on long runs. Sure it looks good on a dyno but how long is your motor going to last you.
Stao, I have one of your 17psi actuators which I bought from here, I tested it out and the thing does not open up to 25psi... It starts opening around 19psi... I really think you should use some higher quality actuators. Garret parts are cheaper than the actuators you have and should be of better quality and provide a straight and consistent boost level.
Its a sloppy setup having an actuator which opens randomly when on boost. On this low pressure actuator I got from you, sometimes it opens at 8psi sometimes it will shoot up to 14psi. Other days it won't go anywhere near 11psi. Its very strange. Air temp wont mean shit, pressure is pressure, if the actuator is holding 10 constant, it should always hold 10 constant. I'm guessing maybe when under bonnet temps or the turbo temps get hot, the spring may get soft causing boost to flop or the spring to work out of spec.
I don't know but I do need to run more boost but scared to do so with these actuators. Are you able to source Garret actuators to fit your turbos? Have you considered kinugawa actuators?
http://www.ebay.com.au/itm/Turbo-Actuator-SUBARU-Legacy-WRX-IHI-VF40-VF46-15-Psi-/280712012508?pt=AU_Car_Parts_Accessories&hash=item415bbd62dc
I really dont want external gate boost control... That will totally eliminate any stock looking setup.
My old gt3071 high flow had perfect boost control to 14psi. These actuators feel very lazy.
I manage to hold boost pretty well? Drops off around 2psi towards redline, that's deliberate though.
What boost controller do you have? These actuators are really inconsistent. Check Taos last couple of posts, he had one of his high pressure actuators spike to 25psi. You cant make the actuator open earlier then it should, a boost controller can bleed off air to delay the actuator opening so unless your boost controller has a near perfect 17psi spring fitted in it, its maybe just a one off that it is holding 17psi allowing you to control 18psi. I'm not worry about it tapering down, my concern is the initial boost level and the fact that you cannot control this. Bleeding off air will only cause the boost controller to open later.
Greddy Profec Bspec II.
First of all turbos are different with unique wheel design as well as housing and gate sizes. Means the back pressure in them are not the same. So high pressure actuator only means it hold certain pressure on the turbo that has been specifically made for, refer to what I was originally asked to build.
If you run an actuator from a different turbo to on some thing else obviously its going to give different readings. Eg. If I run an actuator that made to hold 18psi on a .58 rear housing, then that actuator will hold 24psi on a .82 rear housing. As the back pressure from the .58 is lot greater then the .82. Only means its not the correct part, does not mean its bad quality.
That is why I asked you to keep the original actuator I've tested and supplied with the turbo, or buy it back from my self. Have a look at my boost pressure curve for the SS2, that is a perfect actuator for that turbo.
In terms of High pressure actuators we have 4 different spring settings so I guess you've fitted the strongest one by luck, same as what I've fitted on the SS1-PU.
Oooh yeah. Just paid for the pu prototype. Excited to see how she goes.
Will post up results when the cars been tuned.
What are you strapping it onto? Your profile lists a GTR, are you going single turbo on the RB26?? If so I will be very interested to see how this goes!
Just organized another actuator from Tao, designed for my turbo! Excitement rising!
He mentioned something about an RB25 drift car at some stage, I forget where...
Ah cool.
Can you PM me your Profec B spec 2 settings and what boost you are running on high and low? Ive got the same controller so Ill use your settings just as a guide line for when I get the high pressure actuator. What is the max boost your greddy controller stores on your boost settings?
My high settings read about 11.3psi and low is about 10psi. Sometimes a 13psi spike on high. High is 100% too lol.
Ah cool.
I'll check all my settings for ya tomorrow mate :thumbsup:
Probably want some thing knocks less on high boost.
Also For people who's thinking doing Z32 ECU with Nistune on R33. Don't do it. I'm having so much trouble getting it to work, they are unreliable, and many areas that can’t be touched.
Big thanks Trent's spent 6 hours tuning and try to fix it and it just don't work.
I'm thinking of modding the illustration car back to stock or going for a PFC or Link ecu for my next run.
Uh oh. I have a about 5 z32-r33 nistunes to do this month. U have me scared now. With my drift car ill be running a rb20 ecu with a msd or similar rpm window switch.
Boys the prototype pu turbo will be going onto a customers R33. Very tidy car running power fc, 3inch etc. And a profec B i fitted to it last sunday.
My r32 gtst with rb25 drift car is running a different turbo
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
