Ive struck some back luck - picked the car up early from the tuners today.
Car makes boost as expected but does not make power. There is either a blockage or leak in the intake or exhaust system that has gone unnoticed.
Its very unlikely that there is any problem with the turbo or actuator, so I will be checking out all the piping etc as soon as I can and maybe replacing the stock BOV while im at it.
Engine compression is fine and it makes normal power off boost so it has to be something else.
Shitty cat? It annoys me greatly that these "tuners" run into a restriction problem yet either are too downy to think "oh maybe it's teh catz" or that they DO think of it and DON'T bother dropping the exhaust to find out. WTF
well i had a tuner take the liberty of smashing my expensive metal cat without confirming id be ok with this thinking it was blocked.
then still blocked tuned around it and told me its fine but ill need a new cat. ages later i spot the mid muffler on the catback is crushed so i change the catback, pick up infinity KW and pop the motor lol.
long story short sometimes they do look at teh catz a little harder than necessary and give up there. Noob Tuna's.
My car makes boost but also lacking alot of power with the ss2. Tao made 300rwkw on 20, I make 246 on 20. I've got a fat hks, massive 5 inch cat and a jjr dump. We think the intake side is the restriction buy only time will tell, I need an intake pipe, I'm waiting for the units tao is working on. I also run very similar if not a tiny bit more timing than tao.
Making big power requires that everything is basically perfect, not surprising that so many people have issues. Just look at the amount of threads in FI about cars not making the power they should.
Spot on. If its not right it just wont eventuate..
Its the accumulation of parts that gets the results. If you want the results Stao gets you will need to mimic his setup.
and even with all the right parts you've got things like silicon joiners leaking, gaskets leaking, broken studs causing gasket to fail to seal, valve float due to old head, injectors unbalanced, etc etc.
Leaks and restrictions seem to be the biggest cause from what I've seen.
Ive believe in my case its an intake restriction. I started getting worried that I might have a tired old motor but a comp test gave good results(155 to 160 across the board). Ive got all the supporting mods I don't suspect any intake leaks. I can never be sure if I do or do not have a manifold leak because I have never checked but if I did I am sure I would know about it.
The biggest bitch is the intake pipe.
seriousily so many ppl whinging about intake etc
go fkn buy a 3" stainless bend, get some smaller stainless tub, take it 2 a fkn fabricator get it welded on 4 your bov return and catch can return and buy a silicon hose 2 join afm and pod and bolt the f**king thing on. take all of about 10mins 2 organise and hour 2 get shit welded on. DONE.
or sit around here whinging about how shit ur intake pipe is and why ur car doesnt make any power blah blah blah.
In your case Sarge, you had excellent results (in both power/response) on 11psi but then adding boost from there did not gain any more power. Therefore I would lean to a flow restriction, a manifold leak would show up as a bad 11psi result as well. As it flows well up to a certain point and then cannot get any more air through.
Yep, simple as that. Mine was $400...
Everyone has done that... cost me $200 installed for boost worx to do it.
Edited by Rolls
Nope SargeRX8 keeps whinging about it...
I bought the 90 deg bend for $20, then two separate lots of $20 to weld the two fittings on, then some pipe and hose to connect so all up prob $80. Was thinking about making a few up and selling them.
$400 for intake ? oh dear....
It depends on what was done. I know SS8_Gohan had a place make him one for $350 that included 2 x 90 deg bends on the exact angle and location that hooked up to his standard airbox with both the ports connected.
If its just for a 90 degree bend and 2 fittings then yeah thats VERY dear!
I got quoted 400 from a shop to make it. I then got quoted $80 from another but they were too busy to handle small jobs. I then got quoted $120 from another shop, then I gave him the car to measure and make it and he dicked me around saying this and that was in the way, I cant do it because of this etc. So I ended up making one my self and it was shit.
Until your f**ken sure what you're going to do and how you are going to set everything up, why the f**k would you outlay such money on something which has the potential to change? I was running an atmo catch can. I removed it. Tao suggests running the Z32 in the cooler pipe. What if I done the same? Going to go hack up a freshly made $200 pipe after being f**ked around by most places in my area trying to get one made the first time?
I'm not bitching and I wasn't f**ken whinging. I simply stated my car was not making the power because of the intake. Did I, in any point, in any of my f**ken posts, start talking shit at people because my car wasn't making power? I complemented the latter tuner of my car, I complimented Tao on the turbo etc. No where did I accuse, bitch or whine about the intake pipe.
Matter of the fact is it IS the biggest issue when setting up a new turbo. No car will be the same. There is no off the shelf option like a dump, or a cat. You need to find someone who will measure it up, make it right and make it fit and I haven't found anyone yet.
f**k you.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
