hey stao, im looking to make around 300kws on my neo engine what would be my best bet to do to achieve this result?? highflow, or something else? and what sorta price am i looking at cheers
Edited by skyzthalimit
not as of yet but obviousley mods will be used in conjunction to achieve this goal, aslong as turbo is right should be straight forward on what is required to reach 300 its just a ball park figure not gona be upset if its 280
Ur running the SS1 Harey?? So assuming ur at 260rwkw, hows the response and more important, the punch-in-seat feeling in ur R34??
Yeah I am running the SS1 but I could only make 245rwkw on 98 on 20psi dropping to 18psi. The exact same turbo on Tao's car made 265rwkw but a few more psi starting at 23psi. Then I put it on E85 and made 280rwkw with even better response, its a pretty dam good street setup but if you can make 260-280rwkw with the same response with an SS1PU then sounds good to me.
Regarding intercoolers I upgraded my crappy intercooler to an ARC turnflow. It improved my response by 2-300rpm and Trent said the temps did not rise after 7+ runs and it is ready for some track work. On smaller engined turbo cars I think a responsive efficient intercooler is really important. Whereas larger engined turbo cars like XR6 turbos its not as important as an extra 1-200rpm of lag is not a big issue as long as the air is cool.
Is it a street car? I wouldn't do it.
Yep, on my only [daily] car. Maybe a couple track days a year.
Haha, you are the other voice in my head telling me not to do it. Then theres the other side saying "Nahh she'll be right, a bit of lag will be alright". Its either that or go the standard 0P6 highflow - 250'ish rwkw.
Edited by LANDSCRIBBLE
It will be slower, there is no good reason to do it. Why do you want a slow car?
Yeah I have to agree with the ATR43G3 being a bad turbo for mostly a daily driven street car. It will be annoying as you will go to accelerate to change lanes etc and you will be waiting for boost for too long. Its completely different on a track car where you will keep the turbo on song as the car will always be above 4000rpm anyway.
It is the transient response that kills it, it isn't just rpm, it is time it takes to get on boost.
It will be slower guaranteed, slower off the line, slower in traffic, slower in the hills (most of the time), faster on the track and drag strip.
Edited by Rolls
yes i have been in plety and all setups react differentt weather your running same parts on a idential engine i just reacon saying 250 kw to say 280 290 that he wants is gona so called reck its street value unless its on a track its just not true
250kw is the sweet spot for a road car, you can get that with almost stock response.
This could be a debate of sorts. Many people in here recommend 270-280rwkw is as far as you wana go for a very responsive and very quick 2.5L street car. I havent been un one so cannot say, but that IS my power goal..
Yeah if you get it right, most people who go 280kw choose a turbo that can do 300+ hence why it isn't optimal, and most people that buy a turbo and expect 280 with response have issues(?) and can't get it there, eg I think it was hanaldo? who has pretty much everything spot on but still couldn't replicate staos 280 due to something not being 100%.
If you go E85 then totally different story though.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
