Kasko - I got mine done at a 4wd specialist and they quoted $350, asked for $450 and I paid $350 after some arguing.
Stao. Will that little extension work for my turbo with boost drop issues?
Anyone wanna change my clutch so I can join this race :(
Got quoted $500 for the change
I got quoted the same amount (including flywheel machining) and Im on the Central Coast NSW....
that was from a brake and clutch place though...
so I'll do it myself I reckon... its just heavy, everything else is straight forward.
How much power are you running to want to choose from those expensive clutches?
Im running 290rwkw soon to have E85 and jump to about 320rwkw..
Im looking at running Exedy extra extra extra heavy duty clutch $738 abouts...
that clutch will just hold onto 330..
NPC 10' carbotic..about 750$ Simon-s14 uses on his drift car holds 360kw no worries..Few other people have said they are great too..nice soft pedal feel
allthough really if your going to race it you want the flywheel as well (it has a cooling panel to prolong clutch life) which is another 450$..but you could run without it..
thats what im getting anyway.. :thumbsup:
its actually rated alot higher than that, the extra extra HD holds 330, this will hold alot more...
Hamish is abusing it on his 325rwkw ProS setup, been using it a while too...
But I'll look into the NPC clutch too thanks...
Just a note. The excedy heavy duty can't hold 200kw. IN POOR CONDITION
So yeah. If it was new, it was bed in wrong or driven bad and ruined.
200kw is stock clutch territory.
Right now I am tuned to about 240rwkw.
In the future I may chase 260-270 on E85
So just need something that can handle up to 270.
so you could getaway with NSK-7056HHDB for $691
Power Holding Capability (At Flywheel): 499hp / 372kw
Oh ok, there's an extra extra on the extra extra...
I guess Hamish buys clutches like he buys his clothes...:laugh:
Are these street friendly clutches?
Button clutches are normally the ON or OFF type?
Buttons take a lot of effort to drive and maintain IMHO.
The HHHDB (3x heavy duty button) normally gets sticky in traffic and wont like to shift easy or come out of gear. If you know how to use it and stop it from doing that, they are OK.
I would rather have a HHHD which is the 3x hd without the button. It just makes it easier to manage and less stress getting around. It will be forgiving like a normal clutch, where as the buttons dont appreciate driver error. Your passengers will appreciate it even less lol
seems excessive though to spend $1200-2000 on a clutch for the sort of power were talking about here...
any suggestions for better clutches then that dont go over $1K
I use PBR made Clutch Industries RPM kits. They don't exceed the $400 mark too often and have not had one let me down yet.
I havent used one on a 500hp skyline though lol
Ive had exceedy brass button clutch it was ok for around 300rwkws. Other wise try extreme clutch. I had them in my 300zx and sil180, they are good.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
