Hey Stao - if my AX53B70 ever goes kaput do you think you could make something up for me with the housings off it? It looks like it could do with a couple more mm in the both the compressor and turbine wheels. So far it has been nothing but rock solid but I only use at 1bar max. Thought I'd ask as I wouldn't mind pushing it a bit more.
I'm only looking for 250-260rwkw, I figure the turbine housing on this would be ideal for that power level.
Edited by simpletool
Yeh well I wouldn't expect it to be a hell of a lot, but considering I'm chasing a restriction in my setup somewhere, I just want to know that everything is as good as it can be.
Run it without a dump pipe :whistling:
The problem with large internal gate is boost control. means it will have more boost tappering off in general as there will be more load on the actuator. It is a bit of a concern on the new .82 IW housing assembly, might need to run a 2~3 actuator setup or some thing similar to eliminate boost drop.
one off 38mm internal gate SS1 turbine housing.
Have big gate keeps the turbine housing cooler, but harder to boost control. how ever also depending on applications, we do get XR6 BA turbo waste gate jobs often. From my past experiments bigger gate drops more boost. How ever that was before the innovation of all the wastegate controlling methods that I've used today, So might not have the same drop behavior, while makes more power on lesser boost just like having an external gate.
And yes the machined 3inch Vband adaptor fits All .63 and .82 ATR43 series.
With way too much time on my holiday in Japan to catch up on some reading and not spending as much as anticipated etc I've made a list of jobs to do hopefully before end of the year.
Buy an Adj ex gear and dial in both cams as they are both currently retarded.
Modify or change dump pipe til it matches turbo perfectly. Awaiting Stao's results currently on new v-band piece.
Quieten down rest of exhaust
Section off pod filter and set up a cold air intake
Swap internals of plumb back BOV as I blocked atmo port but it keeps reverting. Need recirc port to open first.
Gas up air con.
And for good measure install WMI :whistling:
Will order bits tomorrow so it starts arriving as I get home :)
We were able to round down the edges right up the gasket.
But unable to open her right up as the walls were getting thin.
Yeah prob only 10mm
She'll be right! Still much better than before!
Should get tuned by Trent next week so will see how the results go
Please let me know your date, I would like to come and witness your tune and take some video footages. cheers
No problem will do!
Getting a mechanic friends to do the work out of hours so could be a one or two weekend job, pending if things go to plan or if we have time.
Haven't booked at exact time with Trent yet but he said he could squeeze me in any time. But will let you know!
Did you get a genuine nissan gasket from JJR for the dump pipe too Tony?
Yup got a genuine turbo gasket set but not from JJR. Including the gasket from the turbo to dump pipe.
Parts to go on this weekend:
  • SS2 Turbo
  • Manifold from Stao which has been opening up a bit for better flow
  • ID 1000 Injectors
  • 3Inch JJR bellmouth dump pipe
  • Cometic plenum gasket (When I do the injectors)
  • Cometic manifold gasket
  • Genuine turbo gasket kit
  • New nuts and bolts
I'm not sure if the stock R34 plenum gasket is rubber or not. you need to get the metal one with rubber O rings in them. I found the rubber ones gets blown out under high boost.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
