so you are changing the compressor cover profile?, if it works you can mod all other G3's for a cost?
i started to fit mine last night, but will take me a month or 2 to do as i am modifying the whole car and only have 3-4hrs
a week to work on it, so if this works im interested
I was confused as in your picture, you have the a comp wheel and housing, and above it is a billet wheel by the looks..
cheers
darren
Edited by jet_r31
Its the profile in the housing. will still be using original cast G3 comp wheel. So the modification can be carried out on any G3s easily (or freely).
The billet wheel was from a SS3 I made a roller version of that as well.
no worries. So do you want as much power as possible out of it or preferably stock response?
i want great response mate. dont forget im rockin an auto so lag will kill me. love it to come on boost early with great midrange.
let me know your thoughts!
Ok I will use same profile that I've done for ssxricho, it will have very similar response to stock while produce more power and torque with a very wide power band.
Dyno reading and reference is at:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__view__findpost__p__6352727
Results from Ball bearing G3 with updated comp profile:
E85 high mounted externally gated: Maxing out at 365rwkws
VS the older G3:
I've also done one more run with the The ATRSL25.5G. Little bit pissed as I'm missing 1KWs reaching 400rwkws. Maxed out at 399.1rwkws. Need bigger cams for the full potential of this turbo. Still, this is the highest power ever archived on stock cam from Trent's dyno library.
Its actually very fast, the power delivery is so gradual theres hardly any wheel spin. I'm getting some mickey thompson drag tyres and hitting the strip soon.I think this one can get into the 11sec mark
Lol awesome!
Also glad to see an ss1pu trapping good speed! Good work Daniel!
Haha I think it's not a great indication, everyone keeps telling me its an insane mph.
Also that the airport is way way different to the actual drags
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
