Haha well the bigger the wheel the more accurate it is! :P
Yeh I'm rechecking TDC every time. Thing is, even if TDC was out, that would give me the wrong degree, it wouldn't give me the same degree every time. The error must be elsewhere. I've tried using a different reference value on the dial indicator, and that gives me a different result. Which shouldn't happen. But I can't work out why it does that...
Yep already tried that. Have also tried doing it graphically, so using another degree wheel and working out the mid point of the numbers on the image. It comes out the same every time. Its strange. When I adjust the gear, the final value stays the same. When I change the reference value the finale degree value changes. It should be opposite.
Nope, I'm calling it quits. I tried moving the dial indicator to the other lobe and setting it up again, end result was the same. So to double check I just took down the dial indicator measurements every 20 degrees and then plotted it in Excel, and it gave me a near perfect valve curve figure. So the dial indicator is tracking the lobe perfectly, it's not an issue with that. I am 100% stumped, I have absolutely no idea what is happening. Doesn't make any sense and nothing I do fixes it.
Starting to wonder if there is an issue with the cam lobe symmetry. But surely it must be something more simple than that, I MUST be making a mistake somewhere. I just can't find it :( 2 whole days wasted doing this shit now :/
Edited by Hanaldo
Car is near Mundaring, Trev.
BUT, I have figured out the issue :D must have come to me in my sleep last night because I woke up knowing what it was. Its because I'm using a 180 degree wheel, bastard thing. I just got unlucky with where the degree value fell on the degree wheel, and lost track of which side of 0/180 I was measuring. So the first time I moved it one of my values was 172 and it all worked and I moved it but only by 4 degrees. Then the next times I tried to adjust it, the degree values had flipped to the OTHER side of 180. So I was getting something like 177-179 etc. but it was on the other side of TDC, which I didn't account for in my formula. Had my first value been at ~100° then it never would have flipped over and I wouldn't have had an issue, I just happened to get a value very close to 180 and 0.
So essentially it was my formula that was wrong because it wasn't accounting for being on the other side. This could still happen with a 360 degree wheel but it would be even more unlikely that the degree value falls close to 0°. But really you just have to be quite vigilant of which side of TDC you are working on
:wacko: lol
Haha soooo after measuring it CORRECTLY this time, I've found that all my adjusting has put my intake cam at... 60° :blink: 60° out now! Haha. Would have expected that far out I would like be hitting valves, but I'm not. Now to correct!
No way. 60 out is about 8 teeth :/
My way was fool proof :whistling: my young bloke was a bit too crook to travel today anyway.free tomorrow If your still having dramas. Hope you get it sorted!
Edited by t_revz
60 out is 4 teeth on mine, each tooth is 15 crank degrees. I skipped a tooth trying to get more advancement on the gear, then ended up skipping it 2 teeth because it wasn't moving (was aware it couldn't be have been correct, was just trying something I knew would makea it move). Then I went to turn it back and accidentally turned it the wrong way, so it was 4 teeth.
All good now, spot on 120 degrees! Just rechecking my exhaust but that should be perfect.
No, when I started the intake cam was at 112.2°. So 7.8° retarded. Its now where it should be at 120°. With 4 different reference values on dial indicator to make sure :P
I think you are the retarded spanner in the works :P j/k, get it sorted man! Cant wait to hear good news!
Haha Yeh well that's what I was doing for the last two days, moving the gear backwards and forwards and not getting anywhere :/ all sorted now, time to out it all back together. I somehow don't think my car will be very driveable until I get a tune now though :(
Those is definitely educational materials. would be great if you can post a write up on those cams.
Below is the latest SL21G, or you can call it the SLSS2 or S(L+S2). Basically the Current SS2 with SL2 turbine in 10cm housing. Its suppose to be on the dyno today, Unfortunately my Walbro 20000262 fuel pump burnt out last night and my car was tolled back by RACV lol. Its getting a 20000267 pump installed very soon and getting tuned in a week time.
Below is photo of the new prototype (and the dead fuel pump):
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
