What's the deal with people taking blurry cropped photos!?!
Was there only one shot left on the film?
The conspiracy theorist in me says that if the photo was clear it would show 12.8 !
Either way 120mph is a great result especially for that turbo.
Not sure what it might be in this case. Same customer posted up a bluer photo of his quarter result on facebook. I will update an more accurate result once I get a responds.
The new wheel combination seems to be working nicely inside 1JZGTE VVTi CT15B housings as well.
Latest result:
Toyota Soarer
1JZGTE VVTi Manual
Car has 650 cc injectors
PFC ECU
Front mount cooler
3 inches turbo back exhaust
Aftermarket exhaust manifold
3 inches metal induction pipe with pod filter.
Most power made was 312rwkws @ 23psi, Left on 293rwkws @ 20psi. Car makes 200rwkws by 4000RPMs with excellent on road driving ability.
Got my new apexi intake today measured 3.5inches
That and a new walbro 450lph pump to replace my old dw300 will hopefully see my ss1.5 sr20 at 280kw
As we tested fuel pressure and it was dropping 6-10 psi up top on the dyno as I'm running a extra bar of fuel pressure over std and my fuel pump can't keep up
Afr were going from 12 to 12.5 as fuel pressure dropped so may gain 5-10kw if we can keep afr constant and Tao tested the 2.5inch intake vs 3inch was 13kw
Will get it retuned in a few months after I buy a new fuel pump
I'm on nismo 740cc side feed injectors and trying to squeeze the most out of then as I'm on e85
43psi base + 14.7psi ontop of base and 25psi boost that's 83psi fuel pressure so flow from the dw300 will drop drastically
Yeah is still slighty down on power to Tao but new intake and pump should put it closer to Tao results
Also most dynos vary abit but a true indication of the power will be down the quarter mile which I'll be testing soon
So far at 250kw trapped 120mph
260kw trapped 122mph
I'm going to test it as is now and after I put on the new intake and pump
Some results sent in from B-Rice:
This is standard 21U high flow on E85 managing 292rwkws on E85 fuel and factory actuator:
Clutch is slipping little up top, and I believe an high pressure actuator should be able to hold boost straight with a gain of another 30kws.
A result sent in from an SS1PU customer. This is the latest version also that has a different compressor that is engineered to hold boost better and more top end.
It is running on E85 maxing out fuel pump. Peek of 301rwkws @ 17psi. With plenty of mid range.
From customer's feed back letter:
R34 GTT (Stock Motor)
Supporting Mods
Blitz FMIC Return Flow
1000cc Injectors
Standard Airbox (Panel Filter)
3inch Bellmouth Full Exhaust
Z32 AFM
Walbro 255 Fuel Pump
SS1PU (latest model)
Scotty's Alloy Intake
CALTEX E-Flex
301.8 Rwkw (18psi peak, drops off to 17psi holds well)
I did a rough overlay of these results with B-rice's
It looks to me like the highflow r34 turbo is one of the top performers in the 300rwkw E85 range
Unless im a total twat and have farked this up haha
Actually, I think it was a R33 21U high flowed turbo. The updated high flow probably works out to be similar to a SS1PU.
There are two profiles for the OP6, we can still use the old configuration which keeps it responsive and maxing out towards 260rwkws while the later configurations would be maxing towards 300rwkws with more lag.
I'm working on a new version of high flow for Rb20det motors. The expected out come will be very similar to a 2530. Will update photos as its been completed.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
