That above is a ATR43SSG4 core, so similar what it originally was.
The VNT system do work and I've been using them a while now for anti lag. This specific method has the potential to knock off about 500RPMs of lag without trading off power. How ever has to be very specific to the amount of back pressure the turbine housing is receiving. Little like setting up Ign timing which at specific point they will allow the engine to output its highest torque while otherwise results the opposite. Some thing worked so well on the RB25det worked horribly on the Kia's High comp G4GC motor. So getting this to work on the Rb30det it will require a new round of research and development.
Posting an result. This is from a SS2 Based High flow that we did for a Auto M35 stagea not too long ago. It made 275rwkws on 20psi with Pump 98 fuel.
Note: The WOT was engaged in a slow manner on run below, for the reliability of factory Auto.
That pic raises another question Tao , is the compressor housing on your turbo a 0.70 AR T04B one ? The larger ratio B housing is one we don't see too often though I don't know why . It would have a bit more flow capacity than the 0.60AR B housing while being more compact than the T04E or T04S ones .
0.70AR B housings have larger 2.5" (63mm) outlets like 0.70 AR S ones .
A .
And any one into Nissan patrol 4.2L Diesels ? High flowed stock turbo made 121awkws on 15psi maxing out stock fuel pump. Stock turbocharger maxed at 81awkws.
  • Like 1
My SLSS2 turned up today
Looks good sitting next to my old highflow paperweight :)attachicon.gifImageUploadedBySAU Community1399964974.687270.jpg
WTF happened to that compressor wheel? What highflow was that?
It is a Kinugawa highflow. The oil feed line let go while coming onto the highway in second at high revs.
  • Like 1
Hoookay
Some initial feedback on the TD06SL220.5G
My car is hardly sorted atm
but is as follows
Dead Standard 1JZ-GTE and Auto
ETM 6 into 1 merge collector manifold
Hypergear 50mm External gate
3" dump pipe into a 2 1/4" mid pipe into a 2 1/4" twin system (yuck!)
factory ECU
So initial drive
Builds boost at around the same RPM as the standard turbos...but feels like it needs a little more throttle to do so
Once it sees around 0.2bar and 3000ish rpm it comes on like a light switch even at under half throttle (no WOT runs re: standard ECU) running the 0.8Bar gate pressure
This combo is going to have a monster mid range once I finish the new exhaust (3.5" with a Hooker super comp aero chamber muffler) and fit the ECU and fuel system
but I feel it is not going to be linear, feels like it will always be a light switch turbo, but comes on early enough to not be a huge worry, however I will report back once its tuned and I drive it in the wet.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
