My car made 324kw with injectors maxed out had faulty coilpacks running 16psi with an ss2 on a mixture of e70.. yet to retune on full e85 with larger injectors and coils
heaps of power for such low boost? first time round I only managed about 310kW with 20 psi. Needed to push it to 24psi to make what I make now and stretch head studs LOL
12074575_958449057532359_191295407393022
Made 280rwkw on P98 with intercooler causing restriction (china 510x250x65) on 17PSI.
Waiting for ethanol content sensor and feature pack nistune to arrive and will couple with a PWR intercooler and go back for e-flex. Pretty damn fast lol. Has 3.70 gears so it's not as stupid as same power with 4.11s but has 100% traction and just hauls lol.
Specs:
- RB25DET NEO: New nissan head gasket, genuine nissan headbolts
- ATR43SS2
- Turbosmart 40mm comp gate off rear housing
- Xspurt 1000CC injectors
- Z32 AFM on factory R31 airbox with lid cut out at rear
- 3" induction pipe
-3" Dump pipe > 4" highflow cat > 3" exhaust with 2 large mufflers
- Nistune ER34 ECU
- 510x250x65 intercooler (china) with 2.5" piping
- Aeromotive 340 fuel pump
Edited by AUSBen31T
  • Like 5
Its been welded onto the standard manifold. If it makes 400 on 20 then il be over the moon but we shall see i havnt got plans to take it back for retune anytime soon unfortunately. Lifes got in the way as it does haha will update when i do though
Just got my injectors from Scotty, tune for my neo with ATR43SS2 ext gate is booked in on 30th with trent, shall post up results.
Any results yet? Keen to see how your external gate ss2 setup went
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
