  • Replies 161
Posted Images
Seriously,,,I'd like to see someone come on board and give Duncan some help.
He can win this championship!!!,,,but money as always is the issue.
The Commodore guys will have new tyres for every round,,,Duncan will not.
Neil.
If Duncan paints his boot hot pink and has a large " Duncan loves men" with a small " and SAU" under neath i am sure we will get some small contributions off our fellow members. lol
I will be sure to donate if he does this. :D
uncle dunc post up a bank account im sure all the f**ker here in sau can help pu a bit
5 bucks a member keeps the d man in a new set of tyres... and a new set of tyres = victory on the weekend
Good idea...
Should do it.
Sponsored by skylinesaustralia.com!!!
That footage I posted on youtube doesn't do it justice, it records in HD widescreen but I've got no idea how to post the good stuff to youtube.
Vimeo.com handles many HD formats natively, and what it doesn't you can easily convert to.. give that a go..
Hey Karl....you've got to bring your car to the wakie round....2x gtrs doubles the chances of one of us finishing lol. The Kumhos had better grip but the durability was poor on the heavy cars on a hot day, and 2 commodores blew front rights under load in turn 1. The guys in Korea are apparently on the job to come up with a better compound.
Actually real sponsorship is an interesting topic for me at the moment. I've had heaps of really valuable help from the people on the car over the years which is why I promote them. But right now if I am going to take on this year seriously I need $5k for a spare motor, without it I can't be confident I will get to every round this year and have a good chance of winning overall, with it I have a damn good chance.
So I am hunting for 5x $1k sponsors, 1 per round to get me there. Both sides of the car + sponsor ride days are available so I need to get moving. And still at about 1/20th of what the other front runners spend.
thanks moneypit just checking it out now...but I was thinking local software to edit the crap out (like sitting on the dummy grid) more than the hosting of the result
I can clean your windshield at the wakie rounds....only live 15mins away lol
Ah,,,the things you find in your in-box.
Sorry Duncan I couldn't help myself. Please don't hurt me,,,I'm an old man remember.
If any of the commodore guys see this,,,please don't take it as rude or offensive,,,It started out as an in house little vid,,,but the naughty pit crew had other ideas.
Neil.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
