  • 3 months later...
Dont bother with them,
Bought one for a mates GTI-R and it fit ... after a mammoth struggle to get it in there.
Bought one for my gtr and didnt come close to fitting, bottom tanks just massivly too thick either that or the bottom mounts are way off. Tried to fit it into mates r31 with more room than mine and also didnt fit. Since i bought it 3 months ago and it now has a slightly dinged up core from trying to make it fit i've just given up on it and written it off, doubt its worth contacting them as i dare say they wouldnt be interested in returning it / exchanging it.
ASI = fail :D
I bought a asi one for my gtr, too thick and cant run the shroud and the thread for temo sensor in bottom was wrong. Put it in the china shit pile and just bought a koyo, bolted right in like factory.
its the same thing with the large koyo rads (3 versions from memory), shroud modding etc.... even the $1000 jap one (largest avail) needed shroud work.
Just purchased there 52mm core radiator for my r32 gtst
The core alone is actually 56mm which made it almost impossible to fit
and the thread for the sensor does not fit either which didn't bother me
Ended up bending a shit load of fins installing it
Had to cut about 1 cm off the clutch fan to make it fit because i wanted to retain the stock shroud
Also had to take off the bottom bracket for the power steering lines
Wish i got the 42mm core from them which would of fitted perfectly
Not sure how it will hold up on the track but will find out shortly
'You get what you pay for'
Will post pics up tomorrow
Cheers
Edited by DFAULT
  • 9 months later...
  • 4 weeks later...
  • 1 year later...
An old thread but i bought one of these today (the importer is my neighbour) and was surprised how thick it was. I could not fit it by just removing the OEM rad and shroud. Onc i removed the clutch fan it dropped straight in and bolted up fine. The temp sensor was also fine. So far so good. I think the quality may have improved as none of the welds looked dodge but only time will tell.
I killed my first one at eastern creek, the fan must have flexed 10mm near redline and contacted the fins at the bottom casing a massive leak.
I just installed my new one i ordered and unfortunately it is leaking from near the bottom tank even without pressure.
I have contacted asi and so far he has been replying without a drama and said he will swap it no problems. I am using a stock 32 radiator for now though and hoping for a refund
I bought one of these 18 months ago. My first one started leaking within 30 minutes of driving. I emailed the seller explaining the situation and he sent out a replacement immediately (also offered a refund), no questions asked. Didn't even ask me to send the faulty one back. Great customer service.
18 months later and it is still going strong and performing well in track duties.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
