Spraying the turbo with WD40 will do nothing to help the situation.
Here is a potential cause.
Having a series 2 your turbo has a bakerlight compressor wheel, a very hard plastic and this could be scuffing on the housing making a squeek or high pitch squeel.
It happens because the shaft wears out and usually there is forward/backward movement in the shaft causing it to push forward on the housing or backward on the backing plate.
It will eventually explode and throw bits of plastic all through your intake soon if the noise is in fact coming from the turbo.
Or you could have a bird in there that is opposed to greater boost pressures.
Kind of like a Nissan Nazi Budgie.
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522541
If anybody watched Top Gear on Monday night and saw the actor who drove the well priced car around the circuit and Clarkeson asking about a string of 911 Porches he had owned. As they were chatting about his string of cars he admitted he new bugger all about them and on one occasion was driving his brand new 944 he had picked up the day before, realising he didn't like it he stopped off at the Porche dealership and got another 911. He couldn't tell Clarkeson what model it was and the only one he could remember was the one he was actually driving to the interview. He couldn't even tell if any of them had been a turbo or RS or wide body.
My point ? If someone knows nothing about a particular car and still can't find the time to read enough to at least make some kind of considered opinion as to how it operates then does he deserve ownership ? Of course he does. That's what money is for. I wonder though why there are no longer any genuine GT Falcons left. GTR XU1's ? E49 chargers ? Because they, (like our Skylines will eventually be) were thrashed, crashed and neglected by people who never took five minute's to learn even the basics of maintainance before asking how their engine blew up. But hey, stuff it, it's just a bloody car after all. I shall now don my fire suit. Let the flaming begin.
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522564
returnaphonecallmuch?
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522620
Some funny replies there. My problem is, i bought a turbo off someone from the forums, put it on my car a few months back cause mine was f*ked and while changing it the gasket was kind of breaking but i had no way of getting another one because it was a public holiday.
So i used the original gasket. On sunday i had an exhaust leak which sounds like its coming from the gasket between the turbo and manifold. I bought the new gasket today and since half my stuff is out i thought i would spray wd40 in there to possibly help the squeak.
I wanted to know if it would hurt the turbo NOT fix it.
Oh and whats a flange?
Edited by WET-25T
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522698
the base of your turbine housing bolts the the FLANGE on your manifold. your manifold starts off with a flange, the item that mates agaisnt your head....
if metal flanges remind you of pussy, you are getting some bad pussy.... real bad
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4522775
I sprayed about 0.00007 cents into it. Just the fro nt wheel, then wiped the remains away when it went to the bottom. Meh, im more annoyed that one of the studs came out of the manifold.
To save me the run around and because i need my car for work asap due to my boss not wanting to pick me up everyday, where can i get a new stud and nut?
Cheers
https://www.sau.com.au/forums/topic/264507-turbo/#findComment-4523250
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
