check out the Top secret prototype pic of R35 and convertible R35
Love what the boys can do these days with photoshop.
Amazing how UGLY as shit that R35 looks in convertible, not surprisingly though the R35 wasn't exactly designed to be the most beautiful of beast's :-)
Although I love how my R35 looks and wouldn't change a thing, its Jap Muscle, not designed to look good in soft top.
  • Replies 60
Just discovered this thread, damn, that is so gay. I want you to picture yourself as an R35 sitting in a showroom. Now a slimy lookin' turd burgler walks in with gangster basketball singlet, track pants, Nike air runners, gold ring on every finger and, yeah, you guessed it, gold tooth caps to work in beautifully with his gold necklace carrying a large clock.
He says to the dealer, "yo' my brother, sup' wit' dat'". Dealer says, "That'll cost ya' a half kilo blood". They get down an' do dat' shit.
Right about now poor R35 is saying, "Noooooooooooooooooooooooooooooo".
Think about it, would you like your arms hacked off and made to work backwards ? How would you like it if someone sliced off your man appendage and sewed it back on above your poop chute ? Then they paint you up like a Smurf and make you parade around in public. Blasphemy !
Love the dish though, yeah, gives me wood. :banana:
You were still saying they were cool 3 days ago when we were in their workshop looking at their actual R35 GTR. lol
The stickers on that photo chopped effort may be what it will look like if they speed run it, the rest mmmnah.
Top Secret make the worst coffee lol
  • 1 year later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
