check out the Top secret prototype pic of R35 and convertible R35
Love what the boys can do these days with photoshop.
Amazing how UGLY as shit that R35 looks in convertible, not surprisingly though the R35 wasn't exactly designed to be the most beautiful of beast's :-)
Although I love how my R35 looks and wouldn't change a thing, its Jap Muscle, not designed to look good in soft top.
  • Replies 60
Just discovered this thread, damn, that is so gay. I want you to picture yourself as an R35 sitting in a showroom. Now a slimy lookin' turd burgler walks in with gangster basketball singlet, track pants, Nike air runners, gold ring on every finger and, yeah, you guessed it, gold tooth caps to work in beautifully with his gold necklace carrying a large clock.
He says to the dealer, "yo' my brother, sup' wit' dat'". Dealer says, "That'll cost ya' a half kilo blood". They get down an' do dat' shit.
Right about now poor R35 is saying, "Noooooooooooooooooooooooooooooo".
Think about it, would you like your arms hacked off and made to work backwards ? How would you like it if someone sliced off your man appendage and sewed it back on above your poop chute ? Then they paint you up like a Smurf and make you parade around in public. Blasphemy !
Love the dish though, yeah, gives me wood. :banana:
You were still saying they were cool 3 days ago when we were in their workshop looking at their actual R35 GTR. lol
The stickers on that photo chopped effort may be what it will look like if they speed run it, the rest mmmnah.
Top Secret make the worst coffee lol
  • 1 year later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
