the 3.5L were only available in the PM35
so its for a PM35. we called it a PM as the P means later model or something which we seem to call a 'series 2' in other cars.
My understanding after trawling for Sway Bar part numbers is;
M35 & PM35; both RWD as these share front end components with 2WD V series & Z33.
NM35 & PNM35 both AWD. Obviously, as you say; "P" denotes series 2.
  • 4 weeks later...
I can get map tracer software and writer for reflash M35 ECU but cost around$6000-$7000.
Software and writer( writer is for only M35) is for import ECU (in Japan)only.
So probably software can not use Australian Z33 Z34 etc ecu.
This means I think English software and writer can not use M35.
How many people want to realtime remap ?
If many people in Sydney I can buy it.
Or Im thinking me and Japanese tuner(he is in Japan) joint then make map for Australia fuel.
Is this interesting?
I have M35 std data so I know about M35 map.
But I do not have writer so Im thinking joint to Japanese tuner.
Me and Japanese tuner will make map for Australia fuel.
How much would you like pay reflash ecu.(your ECU send to Japan and install map data for Australia fuel)
Main thing is to remove throttle restriction and speed limit Toshi. If you can do that you'll have a queue!
A map for Australian fuel taking into account our mods, and being able to be done in Australia, is very appealing.
How much are you looking at charging? How much would you have to charge to make it worthwhile?
Correct, the fuel and timing would be good but I have an Emanage for that. Im interested in a remap of the throttle to connect it to my foot inputs. It seems reflash companies in Japan charge a premium for that so perhaps its difficult to do? What sort of time frame as I need it within a few months Toshi.
If I have tools I can remove speed limiter.
What is remove throttle restriction?
Are you talking about electric throttle?
Do you want to open faster than std?
I know throttle map so I think its able to open faster but power is same.
Looks like std map not good response around 3500rpm and 4800rpm if boosted up.
So ecu map need remap for Australia fuel.
I do not know how much can I charge.
So Im asking.
Well we'd obviously like it as cheap as possible Toshi, but you need to stay in business! Do your sums and work out how much you need to charge?
G-Zone charge about $450+ depending on spec for a complete remap.
We discussed this in a different thread last week and there were a lot of people with Emanage's who would be interested in just removing throttle and speed limiter, not a remap. Is this possible?
G-Zone quote that price on their web site. Check out the recent thread: http://www.skylinesaustralia.com/forums/topic/362400-g-zone-for-m35s/
44,000 yen ($506) for a standard remap, plus 20,000 yen ($230) for throttle restriction removal and speed limiter removal. Most people on here just want the second part, they don't need the first part because they have an Emanage. Not sure if that's possible?
And yes, below 3000 rpm for throttle restriction.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
