Yeqh Scott did. Doesnt open the throttle....
According to Mr Amino at G-Zone it'll work if the throttle restriction is removed though.
Toshi, there are people on here interested in a remap if you can do it for a decent price. If you have the reflash equipment and can use it to remove speed and throttle restrictions you probably double your market.
F-con sounds interesting too, but I can't be bothered driving to Sydney to get the tune done unfortunately. I'm looking at local solutions for now.
According to Mr Amino at G-Zone it'll work if the throttle restriction is removed though./quote]
I'm pretty sure he says we need to use those throttle controller to decrease the sensitivity of of the throttle once the restriction has been removed. That device doesn't actually open the throttle wider.
Edited by ironpaw
I can get map tracer software and writer for reflash M35 ECU but cost around$6000-$7000.
Software and writer( writer is for only M35) is for import ECU (in Japan)only.
So probably software can not use Australian Z33 Z34 etc ecu.
This means I think English software and writer can not use M35.
How many people want to realtime remap ?
If many people in Sydney I can buy it.
Or Im thinking me and Japanese tuner(he is in Japan) joint then make map for Australia fuel.
Is this interesting?
I would definitely be interested in this :worship: This is exactly what people have been asking for since these first appeared. I'm sure there would be enough demand to justify the investment.
I have M35 std data so I know about M35 map.
But I do not have writer so Im thinking joint to Japanese tuner.
Me and Japanese tuner will make map for Australia fuel.
How much would you like pay reflash ecu.(your ECU send to Japan and install map data for Australia fuel)
As others have said; as cheap as possible; but I could probabaly run to a max of $1000 odd for a full remap; I'd imagine this would be something like a Nistune style arrangement?
If so, surely there'd be no real need for an E-Manage, given the tuner would have full control?
Sorry, that's what I meant. Although, how do they decrease the sensitivity once the restriction is removed? By controlling how open the throttle is?
Does it actually do nothing on a car with the restriction, or it just doesn't help with the restriction?
Just thinking how it'd work, I'm curious whether it'd give you the ability to make the throttle restriction worse? (Not that anyone would want to do that, but you know...)
Throttle controllers only change the resistance curve of the pedal, it makes the curve more or less sensitive to pedal input. The ECU wont let the throttle open beyond 26% on my car at takeoff, until 30kph or there abouts. That is what I need removed, I don't really care if the plate doesn't go to 100% at wot as it still flows plenty. The other option is to disable limp mode somehow to allow a cable throttle and TPS but that would probably be harder to program.
Toshi, if the remap was user programmable I would pay over $1000 but a simple reflash shouldn't cost more than $500 I believe.
Teps run a similar configuration with the F-con in p1ggyback configuration. I would be very interested as they seem to know what they are talking about. Can you ask them if it will work well with the Emanage Ultimate please? Like I said fuelling wont matter as im running 1000cc injectors and e85, I will let the emanage take care of that. Just a standard remap would do I guess.
Can they fiddle with the cam timing also?
At that price very interested. How many people would you need for the group buy and how long would you need the ECU for?
Are you sending them to TEPS? Or are you doing them locally with TEPS data? If its all local I couldn't imagine postage would be that bad.
I don't think the Z33 has the throttle issue we experience. Gzone are willing to remove it as part of their remap so it is possible, but probably not easy as other remaps don't cater for it.
Z33 have 16x16 throttle map.
I think its same M35 (not same map but I think also M35 have 16x16 throttle map)
I will ask G-ZONE about throttle map.
I have a spare ecu and I dont mind being the tester, I can log most data and let people know what changes have been made.
I will need an ecu modified fairly soon though, I have a GTX3071 just waiting to put out 600 hp if I can get the throttle to bloody open. :whistling: How far along are you with negotiation Toshi?
I told I do not have flash writer.
Flash writer and software Cost $6000-7000.
If I have writer I will make data my self.
So I will send to Japan.
Gzone must be fielding a lot of questions from many different people. lol. I have a few avenues to get an ecu flashed by them, what is the benefit of going through you Toshi? :)
Perhaps some sort of swap over system could be organised, im sure more of us would be interested if their car isnt off the road for weeks.
Toshi, if you're getting the ECUs remapped by TEPS, is it possible to get other items that TEPS have made for NM35s? Can you get a list of parts available from TEPS for NM35s? There are plenty of threads on here about their stuff, and I'd be very interested in a few items...
So do you want to make 600hp map?
Or just throttle map?
Std AFM is around 200-220kw max.
I can ask him please send parts thread address.
I will ask parts list.
I run the Greddy Map sensor for fuelling, I think it takes over at 2psi or there abouts.
If they do a hard tune for the stock turbo that will do, it will be more practical and enable an easy sale if I ever want to get rid of it I guess.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
