hmm i might try that tomorrow then.
there is ignition timing and additional boost on the nismo - actually not sure about the boost increase.
well i know the arx MUST be tune differently as from factory it runs a few psi extra.. and who knows if nissan advanced abit of timing to compensate for the extra ass...
Getting back to informeter and modifying the signals from these 2 pots, when I made changes to increase opening from 80% to 90%, the informeter would read LESS than 80% (closer to 70% actually) and then the ECU would back off the fuel (cause it thinks I don't have the throttle opened as much as I do) so I would see the injector pulse width drop down (meantime I'm going faster) & of course the knock sensor would put an end to it pinch.gif I'm hoping for better results at the lower end of the spectrum though. There's more fuel at launch and that is where we want the benefit anyway soooo.... we'll wait & see.
seeing as i've got a wideband in maybe me n scott will also figure this one out. but im starting to think it may have something to do with the fuel map as Cihan cant tune the car under 3000rpm when in third, as if he floors it it will kick down to first and jump off the dyno..
so it could also be a possbility that the low end fuel map is muck, as mine does strange things according to the wideband, but once it gets to 3000rpm, ratio sits at about 12v and everything hammers
maybe we could talk Ian into sticking his spare motor on an engine dyno to see if Gihan can tune the emanage to suit! :P
Not that it would really concern Ian or I....but we do like to help when we can.
I think if the transmission has anything to do with it, just an engine dyno wouldnt work i dont think.. Cihan needs to do a track coughroadcough tune from standing still, to full ball in first. Maybe we can get around it with just that(i like to dream)
Now that's a generous offer :thanks: guys.
Edited by Commsman
just food for lhought guys
the voltage range on most tps's is 0-5V
when you hook up an ecutalk display you can configure it to show tps volts or %
but for the % to show correctly you have to calibrate it as WOT isn't actually the max range of the sensor
is there any way to calibrate your display thingos?
and has anyone run the throttle out of the car and seen how far the butterfly is open at 86%?
yeah we already know its a range calibration on the informeter, i mentioned that one page back. at 86% its WOT
thats not the problem. being BTW the ECU retards the throttle to limit torque, we want it back. at almost any cost :P
I reset the Voltage range for the throttle this morning on the the informeter and now see throttle in the 40% bracket when stalling. It was a very brief stall and not completed so this may be a little higher in reality.
I will try to get a proper number later today.
by doing the Throttle position reset or?
is there a way to do it in the informeter??
VQ's have twin TPS signals, 0-5v and 5-0v.
The 36% at stall opening is the big issue, not the 86% once it opens.
Perhaps the issue at stall is just an input to the ecu from the brake. Maybe the nismo has this turned off but for those of us without "awesome", we could just cut the wire....
my thought exactly. i said it earlier but im not too confident in exactly which wire that is.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
